@Jacek369 Your image of the log has been rejected as it contains MAC addresses and this is against the forum rules, to protect your privacy. If you copy and paste the log the forum will auto censor the MAC address for you.
Slow speeds only at peak times (pre lock down this was typically 4pm-11pm weekdays and weekends, post lock down it can be all day during the week) but full speed at off peak times is normally a symptom of high utilisation/contention in your area.
Somebody from the VM forum team should be along in a few days to check your connection and can confirm if there is a known issue with your segment of the network.
Having said that, the upstream power levels are at the top of the recommended range which is not ideal and might need a tech visit to adjust them.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
