Nakydwarrior
  • 13
Message 1 of 24
Very slow download speed after upgrade to 500Mbs
Just upgraded from 200mbs to 500Mbs. Was getting around 130mbs previously. Now getting max around 20-30 download with upload speeds above 30. Ping is 8ms which is incredible!!
cannot understand how I can have such low latency, such fast upload and such atrocious download.
test is via wired Ethernet. Cat 5 cable, yes I know this is limited to 100mbs but I am getting nothing close. WiFi connection is slower on iPhone 11.
the router was upgraded from hub 2 to hub 3
have checked all wiring and it is tight. Even checked the wiring in the wall box in case it was loose
have hard reset router twice with pin. 60 seconds holding down button. This improves it marginally from nothing at all to the speeds above.  
interestingly the virgin recommended speed checker does not identify the hub as being a virgin hub which concerns me
Nakydwarrior
  • 13
Message 2 of 24
Re: Very slow download speed after upgrade to 500Mbs
It gets better!
Nakydwarrior
  • 13
Message 3 of 24
Buffer6
  • 10.42K
  • 92
  • 614
Hero
Message 4 of 24
Your images won't show until they have been checked that they don't contain personal info
Login to your Hub in router mode http://192.168.0.1/  if in modem mode switch to router mode temporarily
click on Connected devices to see what speed you are connected to your Hub
Looks like
Let us know the speed you are connected
To determine if you have a fast connection speed to your Hub
Your images are showing now, and it would seem that you only have two upstream channels instead of four
Nakydwarrior
  • 13
Message 5 of 24
Tried modem mode. No improvement.
Nakydwarrior
  • 13
Message 6 of 24
What is the significance of 2 upstream channels vs 4?
Buffer6
  • 10.42K
  • 92
  • 614
Hero
Message 7 of 24
It's better to highlight and then copy and paste results into the message as images will take longer to show
Nakydwarrior
  • 13
Message 8 of 24
checked connectionand have 1gb connection from ethernet
Buffer6
  • 10.42K
  • 92
  • 614
Hero
Message 9 of 24
It indicates that something is amiss somewhere.
You could try a reboot of your Hub to see if it picks up a better config
You could try login to https://my.virginmedia.com/home/index#.
And run the Broadband test to see if it determines a fault and fixes it
Nakydwarrior
  • 13
Message 10 of 24
1 402750000 -8.5 37 256 qam 30
2 202750000 -3.5 38 256 qam 9
3 210750000 -4.7 38 256 qam 10
4 218750000 -5.5 38 256 qam 11
5 226750000 -5 38 256 qam 12
6 234750000 -3.9 38 256 qam 13
7 242750000 -3.5 38 256 qam 14
8 250750000 -4.2 38 256 qam 15
9 258750000 -5.9 38 256 qam 16
10 266750000 -6.2 38 256 qam 17
11 274750000 -4.7 38 256 qam 18
12 282750000 -3.9 40 256 qam 19
13 290750000 -4.5 38 256 qam 20
14 298750000 -6 38 256 qam 21
15 306750000 -7 38 256 qam 22
16 314750000 -6.2 38 256 qam 23
17 322750000 -4.7 38 256 qam 24
18 330750000 -4.5 38 256 qam 25
19 370750000 -5.5 38 256 qam 26
20 378750000 -6.2 38 256 qam 27
21 386750000 -8 37 256 qam 28
22 394750000 -9.5 37 256 qam 29
23 410750000 -6 38 256 qam 31
24 418750000 -5.2 38 256 qam 32
1 Locked 37.3 6 0
2 Locked 38.9 7 0
3 Locked 38.9 3 0
4 Locked 38.9 0 0
5 Locked 38.9 1 0
6 Locked 38.9 5 0
7 Locked 38.9 6 0
8 Locked 38.6 5 0
9 Locked 38.6 0 0
10 Locked 38.6 0 0
11 Locked 38.6 5 0
12 Locked 40.3 6 0
13 Locked 38.6 5 0
14 Locked 38.6 5 0
15 Locked 38.6 0 0
16 Locked 38.6 0 0
17 Locked 38.9 6 0
18 Locked 38.9 0 0
19 Locked 38.9 0 0
20 Locked 38.6 0 0
21 Locked 37.6 1 0
22 Locked 37.3 8 0
23 Locked 38.9 6 0
24 Locked 38.6 6 0
Refresh data
1 32600000 54 5120 64 qam 4
2 39400046 54 5120 64 qam 3
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
834ncxv9873254k;fg87dsfd;
SFID 21072
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 21071
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
Refresh data
15/04/2021 10:56:45 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:44:48 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:48 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:47 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:46 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:45 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:45 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:44 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:44 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:43 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:43 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:42 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:42 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:41 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 10:43:41 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
