stantheman
  • 36
Very slow broadband with constant drop outs in Whinmoor Leeds
I've got very slow broadband with constant drop outs in Whinmoor Leeds
Seen lots of people in similar position in Leeds, what is going on?
Is the upgrading of the network affecting us all, it's never ever been this bad in all my years
Super Hub3
Down, up & Network log to follow as too many characters to post
Cheers in Advance for the help
1298750000-1.740256 qam21
2202750000-2.240256 qam9
3210750000-2.540256 qam10
4218750000-2.740256 qam11
5226750000-3.240256 qam12
6234750000-3.740256 qam13
7242750000-3.740256 qam14
8250750000-3.240256 qam15
9258750000-2.740256 qam16
10266750000-2.540256 qam17
11274750000-2.240256 qam18
12282750000-2.240256 qam19
13290750000-240256 qam20
14306750000-1.540256 qam22
15314750000-1.540256 qam23
16322750000-140256 qam24
17330750000-0.940256 qam25
18370750000-2.240256 qam26
19378750000-2.240256 qam27
20386750000-240256 qam28
21394750000-240256 qam29
22402750000-240256 qam30
23410750000-1.740256 qam31
24418750000-240256 qam32
1Locked40.9160
2Locked40.9210
3Locked40.3320
4Locked40.9100
5Locked40.3130
6Locked40.3330
7Locked40.3180
8Locked40.3180
9Locked40.3130
10Locked40.3150
11Locked40.3130
12Locked40.3130
13Locked40.9130
14Locked40.9100
15Locked40.9150
16Locked40.980
17Locked40.980
18Locked40.9110
19Locked40.3140
20Locked40.9170
21Locked40.3100
22Locked40.9100
23Locked40.390
24Locked40.3140
1325992344.5512032 qam3
2257999934.5512032 qam4
3393999984.5512032 qam2
4462000124.5512032 qam1
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Very slow broadband with constant drop outs in Whinmoor Leeds
Your Hub stats look OK.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Anonymous
Not applicable
Apart from the 32 qam modulation on the upstream channels.
stantheman
  • 36
Thanks for the prompt reply of help Mike, very much appreciated
Have you checked the 'Check Service Status' at the top of the page ? ….YES SAYS OK
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line......YES SAYS OK
Go round all the accessible co-ax connections and ensure that they are finger tight.....ALL OK
I rather think there's a fault in the network though
BQM Link
https://www.thinkbroadband.com/broadband/monitoring/quality/share/15e9449caca0a28189750ba2cd41945e5f...
Cheers 🙂
