DHaynes
Very poor internet speed
I am in area 7, and I have been experiencing extremely poor internet speed over the last 4 months.  I have phoned the help line on numerous occasions, had an engineer out who only connected a telephone which I did not want, and left over 100 messages.  I have the M200 package and get speeds of less than 10mbps.  The WiFi also keeps dropping out all the time because of the low speed.  I have lost count on the number of times the helpline have just said ‘switch off and on the hub3’ or ‘reset the hub3’, which has now been a daily ritual. THIS HAD NOT RESOLVED THE PROBLEM.  This is getting beyond a joke and this is my last resort before I start putting in formal complaints or possibly start legal action.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Very poor internet speed
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
