Hi all,
I'm having some curious issues. My speedtest.net results are fine, 15ms, 100 down ~15 up, but I'm getting huge issues buffering Youtube videos periodically, and when I ping google.co.uk, am getting returns of 1000-2000ms. This is not always the case, often it is 15ms, but for seemingly no reason it jumps and my connection grinds to a halt.
This is on various wireless hardware (PC, phone, tablet) in different places through the house, buy generally within 3m of the hub and with a clear line of sight. I also have the same issues on a wired fire HD device which leads me to rule out WiFi interference.
I'm attaching a screesnhot of the ping results.
BTW, I have called VM support about 15 times, had an engineer round to fix physical connections and replace the hub, none of which have fixed this issue.
These spikes are also not showing up on a BQM that I set up yesterday, which shows stable ping of ~15ms with spikes no higher than low hundreds.
