on 30-10-2022 22:47
I am on the 1Gig package, but recently my speed is showing as 224.62Mb, how do I get my purchased speed?
on 30-10-2022 23:26
How are you testing? It should be directly wired Ethernet to the Hub.
on 31-10-2022 10:09
It is a direct connection. Should I shut down the Router, wait and then re-start?
