gorroppu1111
Very low upload speeds
For the past week my upload speeds have been terrible - about 0.2 mbps at best.  I have tried restarting and resetting the router, and have checked the status of broadband in my area which reports no problems.  I would be very grateful for any help.  My download speeds seem reasonable at 50-60 mbps.
Many thanks in advance.
Here is my router (Super Hub 2) info:
Downstream:
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)138750000146750000154750000162750000170750000178750000186750000194750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)5.535.315.455.615.525.155.015.05
RxMER (dB)37.0937.0937.0937.0937.9437.9437.3637.36
Pre RS Errors373577294373306292298320
Post RS Errors307283290369306292298
319
Upstream:
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID1234
Frequency (Hz)60300000537000004620000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM32QAM32QAM32QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)42.2542.2541.0439.54
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0003
T4 Timeouts000
0
Upstream burst:
Upstream Burst  Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type16QAMQPSK16QAM64QAM64QAM16QAM
Differential EncodingOFFOFFOFFOFFOFFOFF
Preamble Length36384384646464
Preamble Value Offset39666396396396
FEC Error Correction (T)0557145
FEC Codeword Information Bytes (K)1634348822086
Maximum Burst Size0003055
Guard Time Size224848222222
Last Codeword LengthFixedFixedFixedShortenedShortenedShortened
Scrambler On/OffONONONONONON
Network log:
First TimeLast TimePriorityError NumberDescription
17/11/2020 21:45:41 GMT17/11/2020 21:45:41 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 21:42:58 GMT17/11/2020 21:42:58 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 21:38:54 GMT17/11/2020 21:38:54 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 21:11:51 GMT17/11/2020 21:11:51 GMTError (4)68010302DHCP WAN IP - 82.6.228.217
17/11/2020 21:10:54 GMT17/11/2020 21:10:54 GMTWarning (5)85010200TCS Partial Service
17/11/2020 21:10:43 GMT17/11/2020 21:10:43 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
17/11/2020 21:02:31 GMT17/11/2020 21:02:31 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:59:58 GMT17/11/2020 20:59:58 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:57:16 GMT17/11/2020 20:57:16 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:46:33 GMT17/11/2020 20:46:33 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:38:38 GMT17/11/2020 20:38:38 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:31:54 GMT17/11/2020 20:31:54 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:26:44 GMT17/11/2020 20:26:44 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 20:21:16 GMT17/11/2020 20:21:16 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 19:57:18 GMT17/11/2020 19:57:18 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 19:49:28 GMT17/11/2020 19:49:28 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 19:45:39 GMT17/11/2020 19:45:39 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 19:16:10 GMT17/11/2020 19:16:10 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/11/2020 19:06:48 GMT17/11/2020 19:06:48 GMTCritical (3)82000200No Ranging Response received - T3 time-out
Tags (3)
Anonymous
Not applicable
Re: Very low upload speeds
Three of your four upstream channels are out of spec (The QAM level should be 64).
Upstream:
Channel ID1234
Mini-Slot Size2222
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0003
T4 Timeouts000
0
That and the T3 errors show you have an issue with your line.
gorroppu1111
Many thanks for the speedy response.
I did another hard reset of the router and the upstream status is now as below.
Is there anything I can do from my end or is it a case of waiting for VM to sort out the line?  I'm a bit perplexed as to why it says there are no issues with broadband in my area when I check, if the line is to blame...
Thank you again.
Channel ID1234
Modulation64QAM64QAM64QAM64QAM
Mini-Slot Size2222
Power Level (dBmV)42.2542.2541.5041.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0077
T4 Timeouts0000
  • 23.86K
  • 2.53K
  • 4.33K
You shouldn't be getting those T3's. Call it in so VM can check your connection.
