tonybes1968
Just joined
Very low broadband speeds (1/10) in Tameside
I'm currently only getting about a 10th of what I pay for in Tameside. Anyone else having issues today ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Very low broadband speeds (1/10) in Tameside
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you please
Corey_C
  • 3.96K
  • 216
  • 331
Hi tonybes1968,
Thanks for your post and apologies for the delayed response. Are you still having broadband issues? Some good advice being offered by MikeRobbo, Our remote diagnostics isn't currently showing any issues with your connection.
Cheers,
Corey C
