Raf3
  • 5
Message 1 of 10
Very low Download and Upload Speeds on a 200mbps connection
Hi, I'm hoping someone can help me fix the low download speeds I'm getting on a 200Mb connection.
I have done all the normal hub reset stuff - nothing improved.
Speed test here: https://www.speedtest.net/result/10455798275
The issue has been going on for more than a week now. I'm in London area 15.
I'll add my router stats below in case someone can have a look and tell me how i can fix this.
13310000005.838256 qam25
22670000007.338256 qam17
32750000006.838256 qam18
42830000006.938256 qam19
52910000006.438256 qam20
62990000006.438256 qam21
73070000005.538256 qam22
8315000000538256 qam23
93230000005.538256 qam24
103390000005.938256 qam26
113470000005.938256 qam27
123550000005.338256 qam28
133630000005.438256 qam29
143710000006.338256 qam30
15379000000538256 qam31
163870000004.938256 qam32
17395000000538256 qam33
18403000000540256 qam34
194110000005.540256 qam35
204190000004.338256 qam36
214270000003.738256 qam37
224350000004.438256 qam38
234430000004.538256 qam39
244510000004.540256 qam40
1Locked38.9280
2Locked38.990
3Locked38.9120
4Locked38.9140
5Locked38.9120
6Locked38.9120
7Locked38.9120
8Locked38.9180
9Locked38.6310
10Locked38.9280
11Locked38.9270
12Locked38.9300
13Locked38.9480
14Locked38.9390
15Locked38.6520
16Locked38.6520
17Locked38.9460
18Locked40.9390
19Locked40.31220
20Locked38.6880
21Locked38.6800
22Locked38.91080
23Locked38.9820
24Locked40.3650
Tags (4)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: Very low Download and Upload Speeds on a 200mbps connection
Can you post the Upstream, Configuration and Network Logs as well please.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 10
Raf3
  • 5
Message 4 of 10
Hi Mike,
thanks for looking into this.
Please see the info requested below:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e738ea8859201bfefa3d8615e3b39161d6...
15369995944.8512064 qam10
23940000744.8512064 qam12
34620000244.8512064 qam11
46029998644.8512064 qam9
1ATDMA0010
2ATDMA0010
3ATDMA0000
4ATDMA0020
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
a69834ncxv9873254k;fg87dsfd;k
SFID2864
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID2863
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
21/11/2020 00:08:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 23:28:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 22:38:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 22:23:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:31:48criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:29:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:29:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:29:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:28:5criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:27:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:27:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:27:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
Your >> BQM << needs a few more hours to get any kind of trend indicated but up to now I can see some very poor latency showing.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Raf3
  • 5
Message 6 of 10
yeah i have checked and it says No known issues.
Ive also phoned the number provided - again, no issues in my area
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 10
Your >> BQM << is now showing all red, have you lost connection, changed to Modem Mode or switched off ?
Raf3
  • 5
Message 8 of 10
hi yeah,
i have switched off and rebooted
still getting 1mbps but normal upload speed at ~18mbps
Anonymous
Not applicable
Message 9 of 10
@Raf3 wrote:
hi yeah,
Your BQM is terrible!
You need to contact VM to investigate further.
Raf3
  • 5
Message 10 of 10
haha i know - i was hoping for some suggestions that can possibly help me resolve it myself.
I have been trying to get hold of VM for the past 2 days. After 7 hours wait i managed to get through to support and started performing the usual router reset protocols. After 20min chatting with the guy he told me that his shift is over and will be popping me back into the queue. I lost my **bleep** during that moment! I have been trying to get through to support ever since. LOL!
