speckletrout
  • 5
Message 1 of 8
Very Slow speeds and intermittent failure for months
I have phoned Virgin about the slow speeds.Even after reset and supposed speed boost,it is next to useless.I have emailed them to no avail. Over the past 3 years have had 2 new hubs. I use Ethernet. Changed all cables, did not make any difference. Changed computer ,no improvement.
There must be a power deficiency at the external distribution box.
Wife with Asthma, at increased risk from  COVID 19,works for NHS and forced to go into Nurse facing environment because she cannot work at home due to very slow broadband.
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 2 of 8
Re: Very Slow speeds and intermittent failure for months
How slow is slow?
Are you cabling direct to the hub or via a switch or powerline plug?
Post the Network, Upstream and Downstream logs from the hub admin pages
speckletrout
  • 5
Message 3 of 8
Cabling is direct to the hub
gary_dexter
  • 30.51K
  • 1.89K
  • 4.05K
Message 4 of 8
speckletrout
  • 5
Message 5 of 8
Thanks. I will try,not really sure how to do it.
speckletrout
  • 5
Message 6 of 8
Hope this is it.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14830000008.440256 qam30
218700000012.638256 qam7
319500000012.440256 qam8
420300000012.140256 qam9
52110000001240256 qam10
621900000011.640256 qam11
722700000011.840256 qam12
823500000011.840256 qam13
924300000011.840256 qam14
1025100000011.940256 qam15
1125900000012.138256 qam16
122670000001240256 qam17
1327500000011.540256 qam18
1428300000011.540256 qam19
1529100000011.840256 qam20
1629900000011.540256 qam21
1730700000011.140256 qam22
1831500000011.140256 qam23
1932300000011.340256 qam24
204430000009.340256 qam25
214510000009.440256 qam26
224590000009.140256 qam27
234670000008.840256 qam28
244750000008.140256 qam29
1Locked40.33277
2Locked38.655269
3Locked40.950156
4Locked40.954323
5Locked40.337256
6Locked40.354242
7Locked40.343269
8Locked40.348175
9Locked40.336282
10Locked40.332333
11Locked38.960344
12Locked40.329357
13Locked40.347328
14Locked40.337355
15Locked40.333179
16Locked40.955151
17Locked40.942222
18Locked40.326265
19Locked40.332321
20Locked40.37143
21Locked40.37234
22Locked40.37043
23Locked40.36738
24Locked40.36778
speckletrout
  • 5
Message 7 of 8
17/06/2020 20:18:55 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2020 00:41:7 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2020 08:13:15 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:05:0 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:04:54 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:04:50 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:04:49 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:04:49 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:02:16 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:02:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:02:10 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2020 00:02:10 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:40:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:40:6 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:38:31 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:36:23 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:36:18 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:36:17 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2020 23:36:17 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Chris_W1
  • 4.05K
  • 182
  • 252
Message 8 of 8
HI speckletrout, thanks for the message and we are sorry to see that you are having issues with the service, we cannot see any issues so looks like this could be an issue just for you. I will send you private message so that this can be looked into further for you. Chris.
