Timbradley21
  • 25
Message 1 of 20
Very Slow Upload speed M500
Im currently getting lower than expected (to put it politely) upload speeds for my M500 package.
While download is also below what it should be, its fast enough at the moment 389Mbps the upload is only 3.38 Mbps
As im working from home this is affecting my ability to login and work on files from our office network.
I have tried a router reset, im working in modem mode but use an Asus AC86U router that im connected to through ethernet.
 Ive created a quality monitor, but seems to be showing full packet loss
Tags (3)
Timbradley21
  • 25
Message 2 of 20
Re: Very Slow Upload speed M500
Status
331000000
Locked
Ranged Upstream Channel (Hz)
46200007
Locked
Provisioning State
Online
Downstream
13310000008.938256 qam25
22670000008.337256 qam17
3275000000837256 qam18
42830000008.537256 qam19
52910000008.538256 qam20
62990000008.537256 qam21
7307000000938256 qam22
8315000000938256 qam23
93230000008.538256 qam24
10339000000938256 qam26
113470000008.937256 qam27
123550000009.138256 qam28
133630000009.338256 qam29
143710000008.938256 qam30
153790000009.137256 qam31
163870000009.338256 qam32
17395000000938256 qam33
184030000009.337256 qam34
194110000009.537256 qam35
204190000009.337256 qam36
214270000009.437256 qam37
224350000009.538256 qam38
234430000009.137256 qam39
244510000009.538256 qam40
1Locked38.631290
2Locked37.613580
3Locked37.615150
4Locked37.315820
5Locked38.615920
6Locked37.618720
7Locked38.919770
8Locked38.621820
9Locked38.627250
10Locked38.635070
11Locked37.640860
12Locked38.646160
13Locked38.654960
14Locked38.666540
15Locked37.680360
16Locked38.697700
17Locked38.6105490
18Locked37.6132780
19Locked37.6157400
20Locked37.6183790
21Locked37.6212330
22Locked38.6263560
23Locked37.6328880
24Locked38.6372800
Timbradley21
  • 25
Message 3 of 20
Upstream
14620000744.3512064 qam3
23259999344.3512064 qam5
33940001444.3512064 qam4
45370001244.3512064 qam2
3ATDMA0000
4ATDMA0000
Timbradley21
  • 25
Message 4 of 20
Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9834ncxv9873254k;fg87dsfd
SFID264
Max Traffic Rate690000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID263
Max Traffic Rate44000000
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 20
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Timbradley21
  • 25
Message 6 of 20
SamKnows shows
Latency
20.7 ms
Jitter
5.29 ms
Download
304 Mbps
Upload
5.90 Mbps
Timbradley21
  • 25
Message 7 of 20
im on the M500 package which when I first started beginning of December, figures were 500Mbps+ and upload 30-40Mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 20
A couple of things ...
Can you try a different ethernet cable to test with, preferably a Cat 6, they are known to go bad.
You are actually on the 600Mbs package !!
Timbradley21
  • 25
Message 9 of 20
Ha, well they did mention there would be an upgrade to 600Mbps sometime this year!
New Cat6 cable test
Latency
18.8 ms
Jitter
3.86 ms
Download
381 Mbps
Upload
6.69 Mbps
Timbradley21
  • 25
Message 10 of 20
Another cable test
Latency
94.2 ms
Jitter
82.7 ms
Download
444 Mbps
Upload
4.42 Mbps
