lrussell2006
  • 6
Message 1 of 7
Very Slow Upload Speed
In the last 24 hours my upload speed has shot to well below 1mbps.
I'm on M350 and the download speed is exactly as it should be in the region of 300-350 but the upload is on average about 0.1-2mbps which is getting very annoying.
I've restarted router multiple times and left it for 24 hours with no difference, please advise what I should do now?
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Very Slow Upload Speed
How are you testing the speed, Wi-Fi or ethernet connected device ?
lrussell2006
  • 6
Message 3 of 7
Ethernet connected directly as well as through the WiFi just to make sure.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
lrussell2006
  • 6
Message 5 of 7
Thank you so much for your thorough replies, it looks like its gone back to normal speeds for now so fingers crossed it was just a weekend glitch!
Will come back to this if the slow speeds return!
Thanks again!
sparikian
  • 8
Message 6 of 7
I'm having same problem as lrussell - very slow upload speeds, having done a pin reset, plugged into Hub 3.0 etc etc etc.
I have set up a BQM - can I send that to you tomorrow once it has gathered data please?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 7
@sparikian wrote:
If you want assistance please start your own thread.
