bradaw42
  • 5
Message 1 of 8
Very Slow Upload Speed M350 Hub 3.0
Good afternoon,
Since Friday 3rd July the upload speed on my Broadband is extremely slow to none existent and is now a hinderance to me being able to work. I am usually connected to my companies VPN and WFH (for 3 years) everything works just fine - however as mentioned it's now a problem and I think there is a real issue.
I went onto the recommended speedtest.net to perform these checks:
Pre-HUB turn/off/on
On works VPN
WIFI:
Download: 61.11 mbps
Upload: 0.72 mbps
Wired:
Download: 27.73 mbps
Upload: 0.33 mbps
Off works VPN:
WIFI:
Download: 61.57 mbps
Upload: 0.37 mbps
Wired:
Download: 33.81 mbps
Upload: 0.71 mbps
After turn/off/on at HUB for over 30 seconds.
On works VPN
WIFI:
Download: 37.53 mbps
Upload: 0.62 mbps
Wired:
Download: 63.28 mbps
Upload: 0.66 mbps
Off works VPN:
WIFI:
Download: 68.79 mbps
Upload: 0.30 mbps
Wired:
Download: 46.80 mbps
Upload: 0.55 mbps
As you can see the upload speed is very slow to near unusable for my work.
Find below stats from HUB as help forum requests.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1203000000-6.538256 qam9
2211000000-5.538256 qam10
3219000000-7.238256 qam11
4227000000-7.937256 qam12
5235000000-7.238256 qam13
6243000000-8.738256 qam14
7251000000-7.738256 qam15
8259000000-838256 qam16
9267000000-9.737256 qam17
10275000000-838256 qam18
11283000000-8.937256 qam19
12291000000-937256 qam20
13299000000-7.938256 qam21
14307000000-937256 qam22
15315000000-837256 qam23
16323000000-8.438256 qam24
17363000000-838256 qam25
18371000000-9.737256 qam26
19379000000-8.537256 qam27
20387000000-8.538256 qam28
21395000000-10.437256 qam29
22403000000-8.537256 qam30
23411000000-8.238256 qam31
24419000000-938256 qam32
1Locked38.9288754293879
2Locked38.92315593660
3Locked38.61225978100630
4Locked37.3953822436094
5Locked38.9959970382183
6Locked38.61045574115413
7Locked38.929883096
8Locked38.61044124072
9Locked37.639414278925
10Locked38.9286388166799
11Locked37.6524776212744
12Locked37.6739041605
13Locked38.6285071253
14Locked37.6995751712
15Locked37.623989239
16Locked38.6393847124357
17Locked38.91162236
18Locked37.62335638
19Locked37.61217
20Locked38.6230321
21Locked37.313220
22Locked37.6640
23Locked38.6371580
24Locked38.940280
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1257999475.1512064 qam6
2462000005.1512064 qam3
3394000005.1512064 qam4
4326000005.1512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
bradaw42
  • 5
Message 2 of 8
Re: Very Slow Upload Speed M350 Hub 3.0
07/07/2020 13:04:49noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:50:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:49:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:47:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:47:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:47:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:47:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:46:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:46:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:26:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:26:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:22:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:22:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:22:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:22:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:21:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:20:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:17:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:17:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2020 12:13:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 3 of 8
Could you check the connections are tight on both sides of the cable between the HUB and the wall socket?
bradaw42
  • 5
Message 4 of 8
I've checked those, they are all tight and appropriately connected.
Anonymous
Not applicable
Message 5 of 8
You are getting a lot of 'Post RS Errors' which normally means there is an issue with the line.
You'll probably need to contact VM on 07533 051 809 (Text), to get an engineer out to investigate further.
bradaw42
  • 5
Message 6 of 8
Are you saying I need to text that mobile number to get an engineer out?
Anonymous
Not applicable
Message 7 of 8
It starts the ball rolling as it were, unless one of the VM staff respond to this thread first.
Martin_N
  • 5.56K
  • 232
  • 318
Message 8 of 8
Hi bradaw42,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issues you're having. I have taken a look on our side and it does require an engineer to resolve.
I will private message you so we can look into this.
^Martin
