psonani
  • 8
Message 1 of 11
Very Slow Speed with Hub3.0
I am getting <2Mbps speed while doing speed test. I have got line of 100Mbps but not getting that speed.
Technician also tried a lot but not able to find the reason.
How to resolve this issue ? can anybody guide ?
it is very difficult to get hold of the technical support team even after waiting for 1 hour
Prakash
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 11
Re: Very Slow Speed with Hub3.0
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
psonani
  • 8
Message 3 of 11
eRe: Very Slow Speed with Hub3.0
Yes I did, this test and it is <2Mbps speed.  Also tried only connection ethernet cable without any other device connected with win os and diff browsers,Virgin_Media_Broadband_Test.PNG
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 11
Re: eRe: Very Slow Speed with Hub3.0
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
psonani
  • 8
Message 5 of 11
Cable Modem Status
Item
Status
Comments
402750000
Locked
Ranged Upstream Channel (Hz)
46200097
Locked
Provisioning State
Online
Refresh data
Channel
Frequency (Hz)
Power (dBm)
SNR (dB)
Modulation
Channel ID
1
402750000
6.1
40
256 qam
30
2
202750000
4.6
40
256 qam
9
3
210750000
4.5
40
256 qam
10
4
218750000
4.5
40
256 qam
11
5
226750000
4.5
40
256 qam
12
6
234750000
4.5
40
256 qam
13
7
242750000
4.5
40
256 qam
14
8
250750000
4.5
40
256 qam
15
9
258750000
4.5
40
256 qam
16
10
266750000
4.8
40
256 qam
17
11
274750000
4.5
40
256 qam
18
12
282750000
4.4
40
256 qam
19
13
290750000
4.4
40
256 qam
20
14
298750000
4.9
40
256 qam
21
15
306750000
5
40
256 qam
22
16
314750000
5.1
40
256 qam
23
17
322750000
4.9
38
256 qam
24
18
330750000
4.9
40
256 qam
25
19
370750000
5.1
40
256 qam
26
20
378750000
5.5
40
256 qam
27
21
386750000
6
40
256 qam
28
22
394750000
6.1
40
256 qam
29
23
410750000
6.3
40
256 qam
31
24
418750000
6.6
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
7
0
2
Locked
40.3
6
0
3
Locked
40.3
4
0
4
Locked
40.3
9
0
5
Locked
40.3
6
0
6
Locked
40.3
6
0
7
Locked
40.3
5
0
8
Locked
40.3
7
0
9
Locked
40.3
6
0
10
Locked
40.3
8
0
11
Locked
40.3
6
0
12
Locked
40.9
5
0
13
Locked
40.3
7
0
14
Locked
40.3
8
0
15
Locked
40.9
7
0
16
Locked
40.3
7
0
17
Locked
38.9
5
0
18
Locked
40.3
4
0
19
Locked
40.3
7
0
20
Locked
40.3
8
0
21
Locked
40.9
15
0
22
Locked
40.3
6
0
23
Locked
40.3
8
0
24
Locked
40.3
6
0
psonani
  • 8
Message 6 of 11
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200097
4.1
5120
64 qam
1
2
32600000
4.029
5120
64 qam
3
3
25800000
3.854
5120
32 qam
4
4
39400000
4.054
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID
406568
Max Traffic Rate
117000047
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
406567
Max Traffic Rate
10500047
Max Traffic Burst
16320
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
Time
Priority
Description
05/11/2020 18:17:11
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 18:16:8
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30
critical
04/11/2020 22:15:37
Warning!
01/01/1970 00:01:31
critical
04/11/2020 21:51:10
notice
04/11/2020 21:50:59
Warning!
04/11/2020 21:50:38
notice
04/11/2020 21:50:13
Warning!
01/01/1970 00:01:31
critical
04/11/2020 21:24:15
notice
04/11/2020 21:23:7
Warning!
04/11/2020 19:46:12
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:12
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:11
Warning!
04/11/2020 19:46:11
critical
04/11/2020 19:46:10
Warning!
04/11/2020 19:45:46
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:45:45
critical
04/11/2020 19:45:41
Warning!
psonani
  • 8
Message 7 of 11
Here you go - BQM_Link
psonani
  • 8
Message 8 of 11
Please find the below BQM report so far.
psonani
  • 8
Message 9 of 11
Please find latest update, can you suggest what is issue here. I am still seeing speed <2Mbps. No solution is being provided by tech team.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 11
Your BQM is a mess and is showing major WAN side issues.
On your Upstream one of your Channels is at 32 QAM it should be 64 QAM.
You need to phone in and complain about the very slow speeds.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
