  • 42
Message 21 of 35
Re: V.VIP 500mbps issue
Have not just re-booted the hub (No joy) but also restored to default settings but still only getting 79 down and 36 up.
  • 4.06K
  • 190
  • 320
Message 22 of 35
Thanks for coming back to me
Looking at the account it would appear that the outage has been extended to 21/02 with the estimated fix time of 14:20
Very sorry but whilst there is an outage in the local area there's not a great deal our team would be able to do in terms of diagnostics
Please keep yourself up to date with the outage, using the options offered in my previous post, before performing more reboots
Kindest regards,
David_Bn
  • 42
Message 23 of 35
All works have now been completed but looks like I am still capped from Virgin side at a 90mbps download and 35mbps upload, can a MOD check ?
Does this look OK from the MODEM ?
Cable Modem Status
Item
Status
Comments
330750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
330750000
3.2
38
256 qam
25
2
266750000
2
38
256 qam
17
3
274750000
2.5
38
256 qam
18
4
282750000
2.7
38
256 qam
19
5
290750000
2.9
38
256 qam
20
6
298750000
3
38
256 qam
21
7
306750000
3.2
38
256 qam
22
8
314750000
3.2
38
256 qam
23
9
322750000
3.5
38
256 qam
24
10
370750000
3
38
256 qam
26
11
378750000
2.4
38
256 qam
27
12
386750000
2
38
256 qam
28
13
394750000
2.5
38
256 qam
29
14
402750000
2.5
38
256 qam
30
15
410750000
2.7
38
256 qam
31
16
418750000
2.2
38
256 qam
32
17
426750000
2.4
38
256 qam
33
18
434750000
2.2
38
256 qam
34
19
442750000
2.2
38
256 qam
35
20
450750000
2.2
38
256 qam
36
21
458750000
2.4
38
256 qam
37
22
466750000
2.2
38
256 qam
38
23
474750000
2.5
38
256 qam
39
24
482750000
2.5
38
256 qam
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
0
0
2
Locked
38.9
0
0
3
Locked
38.9
6
0
4
Locked
38.9
5
0
5
Locked
38.6
5
0
6
Locked
38.9
6
0
7
Locked
38.9
6
0
8
Locked
38.9
6
0
9
Locked
38.9
5
0
10
Locked
38.9
1
0
11
Locked
38.6
5
0
12
Locked
38.9
0
0
13
Locked
38.9
5
0
14
Locked
38.9
5
0
15
Locked
38.9
7
0
16
Locked
38.9
1
0
17
Locked
38.9
0
0
18
Locked
38.9
5
0
19
Locked
38.9
5
0
20
Locked
38.6
6
0
21
Locked
38.6
5
0
22
Locked
38.9
5
0
23
Locked
38.9
4
0
24
Locked
38.6
6
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
4.75
5120
64 qam
4
2
46200000
4.775
5120
64 qam
3
3
32600000
4.75
5120
64 qam
5
4
25800000
4.75
5120
64 qam
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxxl500u+voc-b.cm
SFID
405776
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
405775
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffort
  • 42
Message 24 of 35
Time
Priority
Description
11/02/2020 12:00:31
Warning!
RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:00:31
Warning!
Lost MDD Timeout;CM-MAC=;CMTS-MAC;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:03:34
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:04:31
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:05:20
critical
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 20:05:11
notice
LAN login Success;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
12/02/2020 19:17:31
critical
13/02/2020 17:47:31
notice
SW Download INIT - Via Config file
13/02/2020 17:50:14
notice
SW download Successful - Via Config file
14/02/2020 04:51:7
critical
14/02/2020 16:03:34
Warning!
15/02/2020 15:30:45
critical
17/02/2020 04:17:29
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
17/02/2020 22:53:26
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 02:46:53
critical
20/02/2020 11:27:23
notice
Unit has been restored to factory defaults from a software issued command;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38
critical
20/02/2020 11:42:13
notice
01/01/1970 00:01:37
critical
23/02/2020 08:39:38
critical
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
BQM:
 https://www.thinkbroadband.com/broadband/monitoring/quality/share/7ae0bec9406b40bc3b6dc2168e2c3bacfa...
  • 3.8K
  • 154
  • 219
Message 25 of 35
Thank you for your post Roboraver7.
We can see that there is a known area fault that may be affecting your services, I'll include some information on this below.
Ref: F007787204
Estimated Repair Date: 27 FEB 2020 14:20
There may be updates available on our service status page, however, on some occasions if this isn't affecting a wide enough amount of customers it will not show on here. If this is the case no need to worry as you can quote the reference above to any of our helpful agents who will provide this for you.
Thank you, Emily.
  • 42
Message 26 of 35
OK I seem to be back up to full speed now, will monitor it for the next week days as the "works" have been completed will see how it performs in the evening but at least I can work correctly now !!
  • 3.8K
  • 154
  • 219
Message 27 of 35
Thank you for the update.
It looks like the fault is still open and the current estimated repair time is 6pm today.
Please let us know how this goes.
Thank you, Emily.
  • 42
Message 28 of 35
Can I mod advise please ? I had to move my 2nd Tivo box into another room (As have to self isolate due to covid19) so replaced the 5 meter provided RG65 cable with a 10 meter RG65 (Only on the upstairs bedroom box, nothing on the main Tivo or Hub 3 has changed) and now my upload speed has dropped. Am actually connecting via a long network cable upstairs directly into the back of the Hub 3 and also other PC's have been speedtested and the upload is the same (5 meg up  instead of 39 meg up while download speed is still the same 550 meg down).
The stats for the download stream look different but do you know if it could just be a Area or Network issue with everyone upload being downgraded ?
Downstream
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
266750000
2.7
38
256 qam
17
2
274750000
2.7
38
256 qam
18
3
282750000
2.7
38
256 qam
19
4
290750000
2.5
38
256 qam
20
5
298750000
2.7
38
256 qam
21
6
306750000
2.9
38
256 qam
22
7
314750000
3
38
256 qam
23
8
322750000
3.2
38
256 qam
24
9
330750000
3
38
256 qam
25
10
370750000
2.9
38
256 qam
26
11
378750000
2.7
38
256 qam
27
12
386750000
2.7
38
256 qam
28
13
394750000
3
38
256 qam
29
14
402750000
3
38
256 qam
30
15
410750000
3.2
38
256 qam
31
16
418750000
2.7
38
256 qam
32
17
426750000
2.5
38
256 qam
33
18
434750000
2.2
38
256 qam
34
19
442750000
2.5
38
256 qam
35
20
450750000
2.2
38
256 qam
36
21
458750000
2.5
38
256 qam
37
22
466750000
2.2
38
256 qam
38
23
474750000
2.5
38
256 qam
39
24
482750000
2.5
38
256 qam
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
4
0
2
Locked
38.6
4
0
3
Locked
38.9
5
0
4
Locked
38.6
5
0
5
Locked
38.9
4
0
6
Locked
38.9
5
0
7
Locked
38.9
4
0
8
Locked
38.9
0
0
9
Locked
38.9
0
0
10
Locked
38.6
0
0
11
Locked
38.6
6
0
12
Locked
38.9
5
0
13
Locked
38.9
4
0
14
Locked
38.9
0
0
15
Locked
38.9
6
0
16
Locked
38.9
0
0
17
Locked
38.9
0
0
18
Locked
38.9
0
0
19
Locked
38.6
4
0
20
Locked
38.9
6
0
21
Locked
38.9
5
0
22
Locked
38.9
0
0
23
Locked
38.6
3
0
24
Locked
38.6
5
0
  • 42
Message 29 of 35
Upstream
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
4.875
5120
64 qam
1
2
39400000
4.775
5120
64 qam
4
3
46200000
4.825
5120
64 qam
3
4
53700000
4.85
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Config
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID
536258
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
536257
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
16320
Scheduling Type
BestEffort
  • 42
Message 30 of 35
Time
Priority
Description
01/04/2020 11:25:38
notice
01/04/2020 09:09:11
Warning!
RCS Partial Service;CM-MAC=xx:13;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 17:07:44
notice
LAN login Success;CM-MAC=xx:13;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 16:39:26
critical
No Ranging Response received - T3 time-out;CM-MAC=xx:13;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 13:35:58
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=xx:13;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 13:17:38
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=xx:13;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.0;
25/03/2020 12:10:40
Error
25/03/2020 11:59:22
Error
25/03/2020 11:18:9
Error
25/03/2020 11:06:52
Error
25/03/2020 10:25:38
Error
24/03/2020 14:44:20
Error
21/03/2020 16:25:52
critical
21/03/2020 14:33:7
Error
20/03/2020 22:48:4
Error
20/03/2020 18:19:32
critical
20/03/2020 07:03:3
Error
16/03/2020 15:21:17
critical
16/03/2020 02:16:1
Warning!
15/03/2020 19:23:57
critical
