  • 42
Message 11 of 35
Re: V.VIP 500mbps issue
https://www.thinkbroadband.com/broadband/monitoring/quality/share/049cb23d280ec594ce1c0c285748770591... Wow, it gone terrible........... Speed via Ookla PING ms 12 DOWNLOAD Mbps 19.70 UPLOAD Mbps 2.08
  • 42
Message 12 of 35
Am having to use my mobile connection tethered to my laptop to post this................. My Broadband Ping - 500 virginshttps://www.thinkbroadband.com/broadband/monitoring/quality/share/049cb23d280ec594ce1c0c285748770591... Do I have 14 days to decide that it's not fit for purpose ? (only installed on tuesday), like many I work from home and need a good connection, will have to go back to Fibre if it's going to be like this unfortunately.
  • 3.78K
  • 214
  • 576
Community elder
Message 13 of 35
That last speedtest looks more like a poor WiFi connection than an ethernet one.
You really do need a visit to get it sorted, but the modem stats are good which is going to make it difficult to persuade the jobsworth on the phone.
I think your best hope is for one of the forum staff to take an interest.
  • 42
Message 14 of 35
But how can it get this bad ? It was only installed on tuesday ?
  • 3.78K
  • 214
  • 576
Community elder
Message 15 of 35
It may have been wrong since it was connected.
  • 1.44K
  • 87
  • 274
Message 16 of 35
Hi Roboraver7,
Welcome to the forums and thank you for posting. I'm really sorry that you've been experiencing issues with your broadband service since joining us recently. Thank you to those who have already provided some great information and advice 🙂
I've had a look at the backend of your services and can confirm that there was an SNR fault raised in your area on 21st May. This is logged under reference F007129297 with an estimated fix time of 9:30am on 29th May. It's likely that this area issue is the cause of your lower than expected speeds, although I can assure you that our team are working to resolve this as soon as possible.
Rachael
  • 42
Message 17 of 35
Thank you all, speeds have been slowly climbing and although no where near the expected speeds it's acceptable so will wait until the works are completed.
  • 42
Message 18 of 35
Can someone explain why the internet speeds for upload and download grinds to a halt between 7pm and 12am ?
Broadband Quality Monitor is showing many lost packets ?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b034658db753acbd742e42462788532349...
  • 42
Message 19 of 35
Our Area 21 had works apparently completed yesterday but I am only getting 90 download and 35 upload, do these modem stats look OK ? do I just now need to wait until a switch is turned on at the back-end from Virgin ?
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
330750000
3.2
38
256 qam
25
2
266750000
2
38
256 qam
17
3
274750000
2.4
38
256 qam
18
4
282750000
2.7
38
256 qam
19
5
290750000
2.7
38
256 qam
20
6
298750000
2.7
38
256 qam
21
7
306750000
3.2
38
256 qam
22
8
314750000
3
38
256 qam
23
9
322750000
3.4
38
256 qam
24
10
370750000
3
38
256 qam
26
11
378750000
2.5
38
256 qam
27
12
386750000
2.2
38
256 qam
28
13
394750000
2.5
38
256 qam
29
14
402750000
2.5
38
256 qam
30
15
410750000
2.7
38
256 qam
31
16
418750000
2.2
38
256 qam
32
17
426750000
2.4
38
256 qam
33
18
434750000
2.2
38
256 qam
34
19
442750000
2.2
38
256 qam
35
20
450750000
2.2
38
256 qam
36
21
458750000
2.4
38
256 qam
37
22
466750000
2.2
38
256 qam
38
23
474750000
2.5
38
256 qam
39
24
482750000
2.5
38
256 qam
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
0
0
2
Locked
38.9
0
0
3
Locked
38.9
5
0
4
Locked
38.6
4
0
5
Locked
38.9
4
0
6
Locked
38.9
1
0
7
Locked
38.9
5
0
8
Locked
38.9
5
0
9
Locked
38.6
5
0
10
Locked
38.9
0
0
11
Locked
38.9
6
0
12
Locked
38.9
0
0
13
Locked
38.9
6
0
14
Locked
38.9
6
0
15
Locked
38.9
5
0
16
Locked
38.6
0
0
17
Locked
38.9
6
0
18
Locked
38.9
4
0
19
Locked
38.9
5
0
20
Locked
38.6
5
0
21
Locked
38.9
7
0
22
Locked
38.9
4
0
23
Locked
38.9
5
0
24
Locked
38.9
5
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
4.775
5120
64 qam
4
2
46200000
4.775
5120
64 qam
3
3
32600000
4.75
5120
64 qam
5
4
25800258
4.775
5120
64 qam
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
11/02/2020 12:00:27
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:00:27
Warning!
RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:00:27
critical
11/02/2020 12:00:27
Warning!
11/02/2020 12:00:30
critical
11/02/2020 12:00:31
Warning!
11/02/2020 12:00:31
Warning!
Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:03:34
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:04:31
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 12:05:20
critical
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
11/02/2020 20:05:11
notice
LAN login Success;CM-MAC=;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/02/2020 19:17:31
critical
13/02/2020 17:47:31
notice
SW Download INIT - Via Config file
13/02/2020 17:50:14
notice
SW download Successful - Via Config file
14/02/2020 04:51:7
critical
14/02/2020 16:03:34
Warning!
15/02/2020 15:30:45
critical
No Ranging Response received - T3 time-out;CM-MAC=:13;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
17/02/2020 04:17:29
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
17/02/2020 22:53:26
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 02:46:53
critical
BQM link is here:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fc9941bb81bde6463bc5a015ee0faa79a6...
Thanks !!
  • 4.06K
  • 191
  • 320
Message 20 of 35
Hi Roboraver7
Thanks for your posts on our Community Forums!
I've looked at the stats of your hub using our software and it all appears to be within spec.
What I have noticed is that we're currently experiencing an outage that has been running from 11/02 at 14:18 until 20/02 10:05
To keep up to date with the outage, please keep an eye on the service status checker - http://virg.in/service or call our Service Status Line 0800 561 0061 for an update
As it stands, I would advise rebooting your hub at approx 11am and run another speed test with an Ethernet connection and the hub in modem mode to see if we can get you the speed of 500mb download
David_Bn
