User108759
  • 113
  • 5
Dialled in
Message 1 of 21
Useless Hub 4.
What a useless piece of equipment!
Try to run inbuilt network diagnostic tool, gets to 12% then logs itself out, log in, run test, 12%, logs out!!! rinse and repeat!
So thats useless then!
Light travels faster than sound, this is why I appear bright, until you hear me speak! 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 21
Re: Useless Hub 4.
What problem are you trying to diagnose ?
User108759
  • 113
  • 5
Dialled in
Message 3 of 21
Re: Useless Hub 4.
Slow wifi.
Anonymous
Not applicable
Message 4 of 21
Re: Useless Hub 4.
what are speeds like wired.
User108759
  • 113
  • 5
Dialled in
Message 5 of 21
Re: Useless Hub 4.
Down speed to hub 497, down speed to 'puter 539 via SamKnows @18:58
User108759
  • 113
  • 5
Dialled in
Message 6 of 21
Re: Useless Hub 4.
Wifi.............
Down speed to hub 492,  down speed to ' puter 118 via Samknows @ 19:00
Anonymous
Not applicable
Message 7 of 21
Re: Useless Hub 4.
do you are getting the speeds to the router. Wireless can be effected by 1000's of factors out of anyone control.
User108759
  • 113
  • 5
Dialled in
Message 8 of 21
Re: Useless Hub 4.
Hub 4 is 24" away from 'puter, so I know it's not a distance issue!🤣
And it appears to be a useless piece of kit............remove cat5(6/7) cable from hub 4, run network diagnostics, now works!
Then said diagnostics tell me I have a few network problems and puts a red triangle next to the wifi...........pity the bloody thing won't tell me WHAT the problem is mind!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 21
Re: Useless Hub 4.
What is your contracted speed ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 21
Re: Useless Hub 4.
Sometimes your devices can be too close to the Hub.
