Electron
  • 22
Message 1 of 18
Upload speeds and hub restarts
Hi everyone.
I've been experiencing some oddities with my connection over the past few weeks and would be grateful for any help.
Earlier this month (11/04), the hub restarted twice in the morning at approximately 9am and then again just before midday. This has happened a few times since and while the download speeds remain good (approximately 100Mb), the upload speed (10Mb) seems to suffer during the evenings. The connection has been very good over the past few years but the upload speed isn't as consistent as it used to be.
I've also noticed that the downstream Channel IDs now run from channels 17 to 40 whereas I remember them being 1 to 24 with lower frequencies. Channels 22 to 24 also seems to have a significantly higher number of Pre-RS errors - is this acceptable?
Around the time this started to happen, I noticed that there as a Virgin Media engineer visiting a neighbour. Could it be possible that work was done in the cabinet which has affected my connection? For instance, I may have been connected to a different tap?
I have a Hub 3 with a 6dB forward path attenuator attached.The tests below were done with a wired connection with the Hub running in Modem Mode. The same performance is observed when the Hub is in Router Mode and a separate router is not being used. No other device was using the connection during the speed tests.
Any assistance would be gratefully appreciated.
Thank you.
Morning
Evening
BQM
968cd63c08179b32de9ed93dd7b5733e2f4308ff-25-04-2021.png968cd63c08179b32de9ed93dd7b5733e2f4308ff-26-04-2021.png
Electron
  • 22
Message 2 of 18
Re: Upload speeds and hub restarts
Hub (Last restarted on 25/04/2021 - Approximately 20:00)
Cable Modem Status
Item Status Comments
267000000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12670000002.238256 qam17
22750000001.938256 qam18
3283000000338256 qam19
4291000000338256 qam20
52990000003.538256 qam21
63070000003.538256 qam22
73150000004.138256 qam23
83230000004.838256 qam24
93310000005.838256 qam25
103390000006.138256 qam26
113470000005.138256 qam27
12355000000538256 qam28
133630000003.738256 qam29
14371000000438256 qam30
153790000002.937256 qam31
163870000003.538256 qam32
173950000002.938256 qam33
184030000003.938256 qam34
194110000004.338256 qam35
20419000000438256 qam36
214270000002.937256 qam37
224350000001.237256 qam38
234430000000.937256 qam39
244510000000.736256 qam40
1Locked38.61580
2Locked38.62130
3Locked38.6890
4Locked38.61650
5Locked38.61040
6Locked38.6860
7Locked38.6510
8Locked38.9630
9Locked38.6360
10Locked38.9420
11Locked38.9530
12Locked38.9310
13Locked38.6820
14Locked38.6440
15Locked37.61600
16Locked38.6450
17Locked38.62450
18Locked38.6650
19Locked38.9540
20Locked38.6450
21Locked37.61070
22Locked37.35140
23Locked37.36410
24Locked36.68600
15370000042.5512064 qam2
23940015042.8512064 qam4
34619994742.5512064 qam3
46029993842.5512064 qam1
1ATDMA0010
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
Electron
  • 22
Message 3 of 18
SFID731694
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID731693
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Electron
  • 22
Message 4 of 18
26/04/2021 20:53:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 11:06:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:53:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:19Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 18:31:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 17:29:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 03:26:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 21:36:35noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 21:36:30Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:29:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:29:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Electron
  • 22
Message 5 of 18
Saved network logs before 24/04/2021.
TimePriorityDescription
24/04/2021 03:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 21:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2021 21:36Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 16:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 17:20noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 11:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/04/2021 20:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/04/2021 11:38noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 20:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 20:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 20:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 20:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 13:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 11:26Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 11:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 11:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
conman33158
  • 1.67K
  • 133
  • 364
Super solver
Message 6 of 18
Your router stats look fine but you have a lot of errors in your network log. Your BQM shows some load on the network as well which could be slowing things down.
I'd start by a full reset of the router to clear the errors and see how quickly they return. Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
Electron
  • 22
Message 7 of 18
I was hoping that one of the Virgin Media staff would be able to look at my connection.
I've been been waiting patiently for 3 weeks and haven't replied because I thought I would be put at the back of the queue. However, it appears there are quite a few recent posts which have have responses from them much sooner so I'm not so sure about the order of the queue.
I have indeed tried a reset of the hub but it hasn't improved the situation. The slow upload speeds are more common at peak times, especially at the weekends so I'm guessing its an area over-utiisation issue or an intermittent SNR fault.
The power levels and SNR values are similar to before, there are some more post-RS errors and a few more T3 timeouts. I can re-post all of the details if that would be helpful.
conman33158
  • 1.67K
  • 133
  • 364
Super solver
Message 8 of 18
Judging by your BQM you do have over utilization, as for Virgin staff not responding, that I have no control over. I think when they see over utilisation they avoid it as there is nothing much they can do about it apart from give possible fix dates and then usually keep moving them forward, although that's not fact but rather just my opinion. Hopefully they will be along shortly.
Laurie_C
  • 978
  • 29
  • 91
Message 9 of 18
Hi @Electron,
Apologies that we have taken a little bit of time to get back to you! I've had a look at your account, and I can't see any known issues or faults in your area. Can I just confirm if you are running the Hub in router or modem mode? If you could re-post the details, that would be helpful, so that we can take a closer look at this for you.
Kind regards,
Laurie
Laurie_C
Electron
  • 22
Message 10 of 18
Hi Laurie_C.
Thank you for your reply. It's good to hear there are no known faults in the area. The slow uploads generally occur in the evenings and the weekends, if that helps.
The current BQM does look better.
The Hub 3 is running in modem mode and the current details are as follows. The last reboot was roughly three weeks ago.
331000000
Locked
60300163
Locked
Provisioning State
Online
13310000005.838256 qam25
22670000002.538256 qam17
3275000000238256 qam18
4283000000338256 qam19
5291000000338256 qam20
62990000003.737256 qam21
73070000003.538256 qam22
83150000004.138256 qam23
93230000004.938256 qam24
113470000005.338256 qam27
173950000002.738256 qam33
184030000003.738256 qam34
194110000004.138256 qam35
21427000000337256 qam37
224350000001.437256 qam38
23443000000137256 qam39
1Locked38.62560
2Locked38.612490
3Locked38.619330
4Locked38.68080
5Locked38.613954
6Locked37.675415
7Locked38.687113
8Locked38.653416
9Locked38.94070
10Locked38.93040
11Locked38.639325
12Locked38.63050
13Locked38.695612
14Locked38.63950
15Locked37.3143517
16Locked38.65510
17Locked38.6243232
18Locked38.64590
19Locked38.64660
20Locked38.64880
21Locked37.615050
22Locked37.653480
23Locked37.375569
24Locked36.693850
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16030016343512064 qam1
24620021143512064 qam3
33939999043.3512064 qam4
45370032643512064 qam2
1ATDMA0030
2ATDMA0030
3ATDMA0000
4ATDMA0020
