22-08-2023 07:42 - edited 22-08-2023 07:42
Hi.
I’m a gig1 customer. My upload speed is struggling to get above 10mbps when checking via Sam knows real speed. Is there anything I can do to fix it? The download speed seems to be working fine
on 22-08-2023 12:25
I’ve just noticed the same thing with my connection in area 26. We have M500, usually get 35Mbps up, yesterday and today 3Mbps. I called VM, went through the troubleshooting steps, none of which helped and have an engineer coming out tomorrow.
on 22-08-2023 13:43
@cbut wrote:Hi.
Lets see the whole data set - thus...
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 22-08-2023 15:20
Hi John thanks for coming back. I have an engineer booked. Seemingly there’s a fault on the line
