scarab
  • 29
Message 1 of 13
Upload speed
Hello,
Running tests on speed my download speed is fine - hovers around 600 Mbps.
However, my upload speed has dropped to below 10
Whilst realise don't need a massive upload it is starting to cause a few issues.
ping seems fine - 9ms to virgin server
R
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 13
Re: Upload speed
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 13
Re: Upload speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 13
Re: Upload speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
scarab
  • 29
Message 5 of 13
Re: Upload speed
Interesting and many thanks for the help. Getting differing speed test from Sam knows being:
scarab
  • 29
Message 6 of 13
Re: Upload speed
I do have the router in modem mode already. The Router Status is:
14190000004.536256 qam36
22510000002.437256 qam15
32590000002.537256 qam16
42670000002.737256 qam17
52750000002.937256 qam18
62830000003.237256 qam19
72910000003.237256 qam20
82990000003.537256 qam21
93070000003.537256 qam22
10315000000437256 qam23
113230000004.337256 qam24
123310000004.437256 qam25
133390000004.536256 qam26
143470000004.437256 qam27
153550000004.637256 qam28
16363000000536256 qam29
17371000000536256 qam30
18379000000536256 qam31
193870000004.936256 qam32
203950000004.836256 qam33
214030000004.836256 qam34
22411000000536256 qam35
234270000004.836256 qam37
244350000004.536256 qam38
1Locked36.352170
2Locked37.313850
3Locked37.615670
4Locked37.316320
5Locked37.320200
6Locked37.619400
7Locked37.322460
8Locked37.625380
9Locked37.327450
10Locked37.628810
11Locked37.324340
12Locked37.325060
13Locked36.626750
14Locked37.326750
15Locked37.327020
16Locked36.625080
17Locked36.324610
18Locked36.328930
19Locked36.335100
20Locked36.339930
21Locked36.638680
22Locked36.347010
23Locked36.348880
24Locked36.352020
15369999648.5512064 qam2
23940000047512064 qam4
34620000047.3512064 qam3
46029994248.5512064 qam1
1ATDMA0030
2ATDMA0010
3ATDMA00100
4ATDMA0030
scarab
  • 29
Message 7 of 13
Re: Upload speed
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
dsfd;kfoA,.iyewrkldJKDHSUBsgv
SFID886
Max Traffic Rate690000278
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID885
Max Traffic Rate44000278
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
10/01/2021 03:13:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 06:23:33noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 06:23:33ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 06:08:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 18:23:34noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 18:23:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 05:28:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 05:28:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/12/2020 22:55:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 17:28:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 17:28:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 18:44:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 05:28:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 05:28:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 01:42:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 17:28:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 17:28:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 14:28:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 05:28:36noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
scarab
  • 29
Message 8 of 13
Re: Upload speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 13
Re: Upload speed
You need to go into your Router Settings and change it to 'Respond to ICMP or Respond to Ping'.
scarab
  • 29
Message 10 of 13
Re: Upload speed
Ahh - done.
Dropped packets more sensible now.
