Kamilka
  • 10
Message 1 of 12
Upload speed
Hello,
Our upload speed is very bad. We can't turn our camera on during a video conference call. If we do it disconnects us. We are paying for 5mbps upload speed but we are getting below 1mbps regularly since wednesday as we test it every day on speedtest.net. Sometimes it's closer to 0mbps. We have not changed anything and tried restarting the router. Our device is a new laptop - all up to date. It was installed about 6 months ago and was all good until last wednesday. Download speed is fine. My question is why is our upload so bad all of a sudden and could someone fix it, please? We didn't get any real help on the phone.
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 12
Re: Upload speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
A Guru will be along soon to decipher the info
Kamilka
  • 10
Message 3 of 12
Re: Upload speed
1139000000-0.440256 qam1
2147000000-0.740256 qam2
3155000000-0.740256 qam3
4163000000-0.540256 qam4
5171000000-0.540256 qam5
6179000000-0.540256 qam6
7187000000-0.740256 qam7
8195000000-0.740256 qam8
9203000000-0.940256 qam9
10211000000-1.240256 qam10
11219000000-1.240256 qam11
12227000000-1.540256 qam12
13235000000-1.740256 qam13
14243000000-240256 qam14
15251000000-240256 qam15
16259000000-240256 qam16
17267000000-1.940256 qam17
18275000000-1.740256 qam18
19283000000-1.540256 qam19
20291000000-1.740256 qam20
21299000000-1.240256 qam21
22307000000-140256 qam22
23315000000-1.240256 qam23
24323000000-1.540256 qam24
1Locked40.328589983588190
2Locked40.34619043268507
3Locked40.336950413530075
4Locked40.330582554373797
5Locked40.370784117459
6Locked40.332602124297957
7Locked40.340739583294208
8Locked40.325056278
9Locked40.313183191
10Locked40.38117180
11Locked40.311260109
12Locked40.320092175
13Locked40.32645766
14Locked40.323599170
15Locked40.312698311
16Locked40.323789182
17Locked40.344635129
18Locked40.311899142
19Locked40.38817867
20Locked40.35257500
21Locked40.314852100
22Locked40.91846143
23Locked40.3370174
24Locked40.3420180
Kamilka
  • 10
Message 4 of 12
Re: Upload speed
15370000051512064 qam6
26030000051512064 qam5
33940000050512064 qam8
44620000050.5512064 qam7
1ATDMA0010
2ATDMA0060
3ATDMA0010
4ATDMA0010
Kamilka
  • 10
Message 5 of 12
Re: Upload speed
General Configuration
Network access
Allowed
Maximum Number of CPEs
3
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt022+voc-b.cm
SFID46854
Max Traffic Rate57500000
Max Traffic Burst10000
Min Traffic Rate0
Primary Upstream Service Flow
SFID46853
Max Traffic Rate5250045
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Kamilka
  • 10
Message 6 of 12
Re: Upload speed
29/12/2020 11:54:51noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:49:38Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:48:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:32:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:29:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:27:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:19:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:19:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:14:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:13:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:11:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:11:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:08:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 11:00:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 10:56:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 10:56:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 10:48:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 10:48:22criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 09:18:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 09:11:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Kamilka
  • 10
Message 7 of 12
Re: Upload speed
Anyone able to tell me if there are any obvious problems, please? What do I need to do? Still very low upload speed and download speed isn't the best. Thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 12
Re: Upload speed
Two of your Upstream Power Levels are maxed out.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
Also your Upstream Speeds are quite low for video conferencing especially in HD or if other applications are also using your bandwidth.
TBH, I hadn't realised that 50Mbs contracts were still in use.
SFID46854
Min Traffic Rate0
SFID46853
Min Traffic Rate0
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Kamilka
  • 10
Message 9 of 12
Re: Upload speed
Thank you for your help. I've done that but it is still the same. Hopefully the VM staff will notice and arrange an engineer visit to fix it. I will also try calling them in the morning to see if I can arrange an engineer visit via that route any quicker.
Kamilka
  • 10
Message 10 of 12
Re: Upload speed
Hello again. Could anyone help us? I see that some people's complaints are looked at faster than ours and we posted sooner than them. Why is that the case? We just would like to get back to normal upload speeds as we are on zoom very often and is one of the main reasons why we got virgin fibre internet.
