Andreaslackner
Message 1 of 5
Upload speed
How can I increase the upload speed? Thank you
Anonymous
Not applicable
Message 2 of 5
Re: Upload speed
upgrade the package to one with a higher upload speed,
what package are you on and what upload speed do you need?
Andreaslackner
Message 3 of 5
Re: Upload speed
I have 100 MB - which is also reflected on download. On upload I have 9 mb and want to increase to handle web calls. Thank you
Anonymous
Not applicable
Message 4 of 5
Re: Upload speed
9mbps should be plenty for web calls
Upload speeds on packages are
M100: 10Mbps
M200: 20Mbps
M350: 36Mbps
M500: 41Mbps
M600: 41Mbps
Gig1: 52Mbps
Andreaslackner
Message 5 of 5
Re: Upload speed
Ok. Helps. Thank you
