Sickbird
  • 18
Message 1 of 9
Upload speed very slow
I have the Virgin 1gb fibre and I was previously receiving the stated 52mbs upload speed but for the past 8 hours it has been slowed to about 8mbs (according to Sam Knows Virgin speedtest).
I have tried turning off the hub (by removing the power) but it is still slow.  Is this a problem at Virgin’s end and is anyone else having the same problem?
Thanks.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 9
Re: Upload speed very slow
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 9
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Sickbird
  • 18
Message 4 of 9
Downstream:
3.0 Downstream channels
25331000000-2.70000138.983261QAM25625
1139000000-0.59999840.366287QAM2561
2147000000-0.70000140.366287QAM2562
3155000000-0.79999940.946209QAM2563
4163000000-1.20000140.366287QAM2564
5171000000-1.59999840.946209QAM2565
6179000000-1.79999940.366287QAM2566
7187000000-1.90000240.366287QAM2567
8195000000-2.09999840.366287QAM2568
9203000000-2.40000240.946209QAM2569
10211000000-2.59999840.366287QAM25610
11219000000-2.79999933.956509QAM25611
12227000000-2.79999935.083549QAM25612
13235000000-2.40000240.366287QAM25613
14243000000-2.29999940.946209QAM25614
15251000000-2.59999840.366287QAM25615
16259000000-2.00000040.366287QAM25616
17267000000-1.79999940.366287QAM25617
18275000000-2.00000040.366287QAM25618
19283000000-2.40000240.366287QAM25619
20291000000-2.70000140.366287QAM25620
21299000000-2.50000040.366287QAM25621
22307000000-2.20000140.366287QAM25622
23315000000-2.20000140.366287QAM25623
24323000000-2.50000038.983261QAM25624
26339000000-2.70000138.605377QAM25626
27347000000-2.79999938.983261QAM25627
28355000000-3.20000138.983261QAM25628
29363000000-3.40000238.983261QAM25629
30371000000-3.20000140.366287QAM25630
31379000000-3.20000140.946209QAM25631
25Locked000
1Locked12039077100
2Locked4236719300
3Locked4234171500
4Locked4205747200
5Locked4217587800
6Locked4215459800
7Locked4219002400
8Locked3613318200
9Locked3617746700
10Locked3610009700
11Locked363140942430
12Locked3612690310
13Locked3601206500
14Locked3613883100
15Locked3610553800
16Locked3765471100
17Locked2556064200
18Locked3755386700
19Locked3760185000
20Locked3788107100
21Locked3784284000
22Locked3783291000
23Locked3801394200
24Locked3436597600
26Locked5275199800
27Locked5256422400
28Locked5279053200
29Locked5271303600
30Locked5281047900
31Locked7897005500
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked -7.49845700
Sickbird
  • 18
Message 5 of 9
Upstream:
3.0 Upstream channels
13260000045.0205995120 KSym/sec64QAM5
23940000045.5205995120 KSym/sec64QAM4
34620000046.0205995120 KSym/sec8QAM3
45370000047.0205995120 KSym/sec32QAM2
1US_TYPE_STDMA0010
2US_TYPE_STDMA0010
3US_TYPE_STDMA0010
4US_TYPE_STDMA0010
Sickbird
  • 18
Message 6 of 9
Configuration:
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
wrkldJKDHSUBsgvca69834ncx
SFID
16755
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
16754
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Sickbird
  • 18
Message 7 of 9
Network Log:
Thu 01/01/1970 00:01:233No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 10/12/2020 20:22:285MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 10/12/2020 20:34:435DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 10/12/2020 21:06:234DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 10/12/2020 21:06:246DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 11/12/2020 19:36:333No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 12/12/2020 16:21:566CM-STATUS message sent. Event Type Code: 5; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 14/12/2020 09:06:244DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 14/12/2020 09:06:246DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 15/12/2020 03:40:523No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 16/12/2020 12:15:296CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 21:06:244DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 21:06:246DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/12/2020 09:06:234DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/12/2020 09:06:236DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 22/12/2020 00:13:536CM-STATUS message sent. Event Type Code: 5; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 23/12/2020 06:30:313No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/12/2020 21:06:234DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/12/2020 21:06:236DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 25/12/2020 16:03:003No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/12/2020 12:45:115MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/12/2020 12:57:275DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 27/12/2020 19:24:406CM-STATUS message sent. Event Type Code: 5; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/12/2020 04:55:434DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/12/2020 04:55:446DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/12/2020 10:29:293No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 31/12/2020 05:14:396CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 01/01/2021 07:31:074DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 01/01/2021 07:31:076DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 01/01/2021 09:46:383No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 16:22:035MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 16:34:195DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 04/01/2021 16:35:403No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sickbird
  • 18
Message 8 of 9
BQM direct link:
My BQM
Sickbird
  • 18
Message 9 of 9
Can anyone help with this?  My upload speeds are constantly in the 2-5 Mbps range and have been like this for over a month.  I see that many other users are having the same problem and the general consensus seems to be over utilisation due to the increased number of users, but frankly Virgin need to make a statement about it because this is not what we signed up for.  The drop in upload speed is significant (even if it was not guaranteed).
