DaftAider
  • 7
Message 1 of 10
Upload speed very slow 10% of plan speed
Hello, forgive my being a newbie - I have the hub 3 - and usually the speed of the broadband is okay - however today the upload speed is showing at 0.9 mb.  The website testing the equipment doesn't show a problem and no one is answering the customer telephone number.  I have logged into the hub and it is showing the following issues;
SYNC Timing Synchronization failure - Loss of Sync
No Ranging Response received
I have tried resetting the hub but hey ho that would not be the solution - can anyone from Virgin Media please read this and help please.  Thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Upload speed very slow 10% of plan speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
DaftAider
  • 7
Message 4 of 10
here you go, thanks Downstream bonded channels
Channel Frequency (Hz) Power () SNR (dB) Channel ID
1138750000-2.7381
2146750000-2.7382
3154750000-3.4383
4162750000-3.4384
5170750000-3385
6178750000-3.2386
7186750000-3.2387
8194750000-3.2388
9202750000-3.7389
10210750000-3.93810
11218750000-43811
12226750000-4.53812
13234750000-4.53813
14242750000-4.73814
15250750000-4.93815
16258750000-5.23816
17266750000-5.23817
18274750000-5.73818
19282750000-5.73819
20290750000-5.23820
21298750000-5.23821
22306750000-53822
23314750000-5.23823
24322750000-5.73724
Channel Locked Status Rx MER (dB) Pre RS Errors Post RS Errors
1Locked38.627581944406726
2Locked38.6513134958067
3Locked38.697925706
4Locked38.6621785571
5Locked38.61034554166
6Locked38.61215832325
7Locked38.91025302233
8Locked38.6364872390
9Locked38.6423911039
10Locked38.63503617
11Locked38.9255750
12Locked38.6363625
13Locked38.62780
14Locked38.62370
15Locked38.62210
16Locked38.92020
17Locked38.91610
18Locked38.61380
19Locked38.61060
20Locked38.6310
21Locked38.65312
22Locked38.6220
23Locked38.6210
24Locked37.67710
DaftAider
  • 7
Message 5 of 10
next part.
Channel Frequency (Hz) Power () Symbol Rate () Modulation Channel ID
139400000495120324
24620000049.55120643
332600000495120165
425799995495120166
1ATDMA0020
2ATDMA0020
3ATDMA0060
4ATDMA0030
DaftAider
  • 7
Message 6 of 10
next bit.
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID6548
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID6547
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBest Effort
DaftAider
  • 7
Message 7 of 10
and the last part, thanks.
08/12/2020 20:11:26criticalSYNC Timing Synchronization failure - Loss of Sync; CM-CM-VER=3.0;
08/12/2020 20:07:48criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 19:32:30criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 19:27:22criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 19:14:46criticalSYNC Timing Synchronization failure - Loss of Sync; CM--VER=3.0;
08/12/2020 19:12:40criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 19:05:27criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 18:58:44noticeLAN login Success; CM-VER=3.0;
08/12/2020 18:30:22criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 18:29:22criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 16:51:16criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 16:50:32criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 16:43:5criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 16:42:31criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
08/12/2020 16:41:10criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 16:39:43criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 16:34:59criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 16:34:25criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
08/12/2020 16:25:50criticalSYNC Timing Synchronization failure - Loss of Sync; CM-VER=3.0;
08/12/2020 16:23:30criticalNo Ranging Response received - T3 time-out; CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 10
Your Network Log is terrible.
You have lots of Pre & Post RS Errors.
Your Upstream Modulations are too low on 3 of the Channels, they should all be at 64 QAM.
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
Can you post a Live Link to the BQM please.
DaftAider
  • 7
Message 9 of 10
https://www.thinkbroadband.com/broadband/monitoring/quality/share/23d5145859fb7bc9f599e6a00edbace51441f2aa
 and here's the link
thanks
DaftAider
  • 7
Message 10 of 10
Tried the power off of the router and waited for about 10 mins.  ran a speed test on a wired connection with 158 mb download and 0.9 mb upload. Still getting critical sync issues with the router.
