Ryanweir92
  • 5
Upload speed unstable
Upload is 4mb instead of the usual 35mb plus. I stream so i need a good stable upload speed but it keeps dropping out which is effecting my apeed on twitch via xbox.
It was fine yesterday but today all day its jist not stable which means i cant stream. Xbox server and system connectiona are stable and live. I checked virgin in my area and it says there are no issues. So why is my upload so low and unstable when streaming and not streaming?
I have checked all connections and cables are secure and even done re sets on both systems and cleared and disconnected anything using the lines but still having an instable upload speed. Please help.
Its beating me down. Any help would be appreciated.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Upload speed unstable
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
