joncb3
  • 5
Message 1 of 11
Upload speed slow
My upload speed is normally around 36mpbs+ im on 350mb broadband. Only noticed the upload speed was very slow when i tried to live stream and i keep getting disconnected or viewers had issues. Tried to go to speedtest.net download is fine around 350+mbps but upload speed is from 2mb to 4.5mb.
i tried to do the test from the virgin hub and my router but got the same results. Virgin status page show that there i no issue. I cant find contact number or live chat in virgin website.
Any help will be appreciated.
Tags (1)
  • 1.84K
  • 114
  • 423
Super solver
Message 2 of 11
Re: Upload speed slow
"i tried to do the test from the virgin hub and my router but got the same results"
Exactly how was a speed test performed from the Hub  ?
Share the results from this link - once started click "Run full test" to show the upload speeds
joncb3
  • 5
Message 3 of 11
Directly from my router as its got feature on speed test.
Also done from chrome. Both virgin hub in modem and router mode. All have same results.
joncb3
  • 5
Message 4 of 11
I cant access the link. Im in my home network and not in a vpn
RealSpeed is not available on this network
To fix this:
  • Make sure you are on your home network.
  • Make sure you are not connected to a VPN (for example, on a work laptop).
  • 1.84K
  • 114
  • 423
Super solver
Message 5 of 11
The Samknows Realspeed test requires VM Hub to be in Router mode.
It is worth a try as it tests the Hub service as well as the speed to the computer.
lojelo5
  • 633
  • 32
Superfast
Message 6 of 11
I'm also in router mode and I'm getting that same message so it's not a problem on his side.
joncb3
  • 5
Message 7 of 11
Same results.
virgin hub download speed 384mb upload speed 4.29
device/desktop download speed 382mbps upload 9.22mbps
  • 1.84K
  • 114
  • 423
Super solver
Message 8 of 11
What to the Hub's upstream channel stats look like ?
For 3.0 DOCSIS we should see 4 or 5 Upstream channels all at 64 qam.
Check for local faults on 0800 561 0061 - if there is noting reported call in your service fault to the Customer Support.
joncb3
  • 5
Message 9 of 11
Thanks. I phone the number you gave it said there is an issue in the area. When i check status online it says there isn’t so maybe the info from the telephone number is more updated.
  • 1.84K
  • 114
  • 423
Super solver
Message 10 of 11
The phone number is more up to date & more local, can be down to one service cabinet.
To get a fault on the post code checker is has to be covering a far larger customer pool.
