Upload speed severely degraded
Hazey
I'm on M500 broadband. This morning I received a text from Virgin Media saying that there may be a problem with my broadband. It requested that I restart the hub3 after checking all cables were secure.
Having done this I checked speed using a wired connection (hub3 is in modem mode) and saw 500mbs down but only 10mbs up (should be 50). I have rebooted both the hub and router but still seeing this very slow upload speed.
Any suggestions please?
1 ACCEPTED SOLUTION
Accepted Solutions
First thing is to check for any “known network faults still ongoing in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
2 REPLIES 2
Thanks...it was indeed a local issue that the online status checker did not identify. Fixed now
