mpwandjbw
  • 5
Message 1 of 9
Upload speed now around 0.3Mbps
Like so many before me, we have now had over a week of poor internet speed.  Download is ok (varies between 80 and 190Mbps), but upload is so slow that email attachments don't work anymore and video conferencing has to be done on a mobile.
I have done all the usual stuff - repowering the virgin box, resetting the VB to factory settings, I have changed the ethernet and coax cables.  All to no avail.
Here is the router log:
10/07/2020 20:06:33 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 20:05:50 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 19:10:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 19:09:12 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 19:09:12 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 19:04:34 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 19:02:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 19:00:0 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 18:54:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 18:50:51 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:44:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:43:47 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:43:47 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:43:20 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:42:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:42:20 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:42:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:38:8 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:34:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 17:32:31 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Downstream channels:
1 419000000 5.9 38 256 qam 32
2 203000000 9 40 256 qam 9
3 211000000 8.6 40 256 qam 10
4 219000000 8.5 40 256 qam 11
5 227000000 8 40 256 qam 12
6 235000000 7.5 38 256 qam 13
7 243000000 7.1 38 256 qam 14
8 251000000 7 40 256 qam 15
9 259000000 7 38 256 qam 16
10 267000000 7.5 38 256 qam 17
11 275000000 7.5 38 256 qam 18
12 283000000 7.8 40 256 qam 19
13 291000000 7.8 38 256 qam 20
14 299000000 8 38 256 qam 21
15 307000000 8.1 40 256 qam 22
16 315000000 7.9 38 256 qam 23
17 323000000 7.8 38 256 qam 24
18 363000000 7.5 38 256 qam 25
19 371000000 7 38 256 qam 26
20 379000000 6.6 37 256 qam 27
21 387000000 6.4 38 256 qam 28
22 395000000 6.3 37 256 qam 29
23 403000000 6.1 37 256 qam 30
24 411000000 6 37 256 qam 31
1 Locked 38.6 16 0
2 Locked 40.3 6 0
3 Locked 40.3 2 0
4 Locked 40.3 5 0
5 Locked 40.3 6 0
6 Locked 38.9 10 0
7 Locked 38.9 8 0
8 Locked 40.3 6 0
9 Locked 38.9 6 0
10 Locked 38.6 9 0
11 Locked 38.9 9 0
12 Locked 40.3 2 0
13 Locked 38.6 10 0
14 Locked 38.9 23 0
15 Locked 40.3 19 0
16 Locked 38.6 9 0
17 Locked 38.9 12 0
18 Locked 38.6 2 0
19 Locked 38.9 15 0
20 Locked 37.6 15 0
21 Locked 38.6 14 0
22 Locked 37.6 20 0
23 Locked 37.6 24 0
24 Locked 37.6 16
0
Upstream channels:
1 46202924 3.9 5120 64 qam 3
2 32600000 3.75 5120 64 qam 5
3 39400000 3.75 5120 64 qam 4
4 53702977 4.079 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
As stated at the top, I have done all the usual stuff - repowering the virgin box, resetting the VB to factory settings, I have changed the ethernet and coax cables.  All to no avail.
Pretty fed up with this and ready to look for another option if nobody from Virgin can help us here.
-tony-
  • 16.53K
  • 1.31K
  • 3.9K
Message 2 of 9
Re: Upload speed now around 0.3Mbps
levels are good - i would pick up on one comment - you have changed the coax cables - where have you got new cables
____________________
Tony
mpwandjbw
  • 5
Message 3 of 9
Hello Tony, thanks for your quick reply,
I have TV coax 'spare', just trying out as many options as I could.  The replacement cable I put in is only about 50cm long.
I am happy to replace it with the original virgin cable.
I will do that now and re-post the virgin box report...
-tony-
  • 16.53K
  • 1.31K
  • 3.9K
Message 4 of 9
as long as its a VM cable then it should be fine - changing the length may slightly change the levels but thats all
Tony
Laurarara
  • 187
  • 11
Up to speed
Message 5 of 9
Upload suddenly rocketed up to 75 and 0.1 for download. Everything dragging along so slowly that I can't open anything much apps wise, nor check my work or look in on my elderly family. 36 hours is the latest 'fix' time and this happened two weeks ago (it was in the National Papers). So it's really weird when customer services say it's only happening to a few people.
mpwandjbw
  • 5
Message 6 of 9
Hi Tony,
I have had a few hours on the 'old' cable now, so speed test comes out as 101Mbps download, 0.15Mbps upload, so still not good  enough to attach email attachments.
The latest router stats are:
13/07/2020 20:39:45 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/07/2020 20:36:18 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 419000000 5.6 38 256 qam 32
4 219000000 8.3 40 256 qam 11
5 227000000 7.9 40 256 qam 12
6 235000000 7.5 40 256 qam 13
7 243000000 7 40 256 qam 14
8 251000000 6.9 40 256 qam 15
9 259000000 6.9 38 256 qam 16
10 267000000 7.3 40 256 qam 17
11 275000000 7.4 40 256 qam 18
12 283000000 7.6 40 256 qam 19
13 291000000 7.5 38 256 qam 20
14 299000000 7.9 38 256 qam 21
15 307000000 8 40 256 qam 22
17 323000000 7.6 38 256 qam 24
18 363000000 7.4 38 256 qam 25
19 371000000 6.9 38 256 qam 26
22 395000000 6.1 37 256 qam 29
23 403000000 5.9 37 256 qam 30
24 411000000 5.6 37 256 qam 31
1 Locked 38.6 17 0
2 Locked 40.3 5 0
3 Locked 40.3 5 0
4 Locked 40.3 6 0
5 Locked 40.3 5 0
6 Locked 40.3 7 0
7 Locked 40.3 9 0
8 Locked 40.3 11 0
9 Locked 38.9 12 0
10 Locked 40.3 13 0
11 Locked 40.3 7 0
12 Locked 40.9 5 0
13 Locked 38.9 8 0
14 Locked 38.9 21 0
15 Locked 40.3 19 0
16 Locked 38.9 6 0
17 Locked 38.9 10 0
18 Locked 38.6 2 0
19 Locked 38.6 13 0
20 Locked 37.6 14 0
21 Locked 38.6 9 0
22 Locked 37.6 13 0
23 Locked 37.6 20 0
24 Locked 37.3 37 0
1 46200000 3.9 5120 64 qam 3
3 39402600 3.75 5120 64 qam 4
4 53700000 4.05 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Any help appreciated. Thanks.
Michael
John_GS
  • 8.7K
  • 476
  • 769
Message 7 of 9
Hi mpwandjbw
Thanks for posting and welcome to the community. I am sorry for the lower than expected speeds. I've had a check on our systems and your area is affected by a SNR issue. (signal to noise ratio). The fault reference for your records is F008204680 and the estimated fix date the 17th July 2020.
Kind regards,
John_GS
mpwandjbw
  • 5
Message 8 of 9
Thank you John_GS.  Its good to at least hear that progress is expected!
Michael
mpwandjbw
  • 5
Message 9 of 9
Thank you John_GS
The fix seems to have solved my problem - I can now upload again!
Thank you...
