jt19
  • 10
Message 1 of 17
Upload speed not exceeding 5Mbps on M200
Upload speeds were consistently around 20 Mbps but for the last couple of months it has never gone over 4 to 5 Mbps no matter what time of day I run the speed tests. Is my line and / or hub faulty?
It seems I'm getting upload speed levels of the M50 package. Have virgin put a hard cap on my upload speeds or is that just a coincidence?
Speed test result
Think Broadband QM
  • 15.93K
  • 688
  • 1.56K
Message 2 of 17
Re: Upload speed not exceeding 5Mbps on M200
Maybe a lot of people upstream video in your area?
Your BQM don't look that good unless you was the one turning the hub off and on?
Do a speed test here
https://www.dslreports.com/speedtest
jt19
  • 10
Message 3 of 17
There was some downtime in my area this morning so BQM looking worse than usual.
Here's the dsl reports speed test , taken using ethernet cable plugged into the superhub.
I did consider it might be due more people working from home, but the upload speed is never more than 4.xx Mbps no matter what time of the day I check. You'd expect most people to be in bed at 3 AM.
My line stats seem fine so the only think I could think of is some sort of hard limit on VMs end.
  • 15.93K
  • 688
  • 1.56K
Message 4 of 17
For some reason the BufferBloat was not tested I wanted to see if your buffering at that speed... maybe try another browser.
You can check your upoad limit in the Operation Configuration of the hub
jt19
  • 10
Message 5 of 17
http://www.dslreports.com/speedtest/64477744
You might be on to something. The buffer bloat meter redlined for the whole duration of the upload portion.
  • 15.93K
  • 688
  • 1.56K
Message 6 of 17
Looks like your buffering in the modem so likely the the upstream scheduler is over loaded with many modems fighting for bandwidth.
jt19
  • 10
Message 7 of 17
Thanks. Is there any action I can take or do I just have to suck it up hope they fix it at some point in the not too far future?
  • 15.93K
  • 688
  • 1.56K
Message 8 of 17
You can wait for the forum team to see what they have to say.
For testing you could try limiting how many devices are connected to just one thats clean to check no other device is uploading and dropping your speed.
jt19
  • 10
Message 9 of 17
Here's my Operation Configuration showing 20Mpbs upload:
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID932
Max Traffic Rate230000061 bps
Max Traffic Burst4000 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID931
Max Traffic Rate22000061 bps
Max Concatenated Burst42600 bytes
Scheduling TypeBest Effort
jt19
  • 10
Message 10 of 17
Stats since rebooting and resetting counters about 20 mins ago:
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)290750000266750000274750000282750000298750000306750000314750000322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID2017181921222324
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)0.700.730.500.80-0.58-0.53-1.06-0.24
RxMER (dB)35.6035.9735.6035.6036.8437.0936.8436.61
Pre RS Errors16119520752788355100
Post RS Errors00000000
