  • 31
Message 11 of 17
Re: Upload speed non existent, impossible to use, Cant get through to virgin media on phone.
I've been having the same issues all last week.  Been on the phone 5 times, only got through twice.  First time was told that I got an upgrade to 100Mbps, said I didn't think that would resolve the issue...it didn't.  Then got told I needed a hub3, said I didn't think that would resolve the issue...it didn't.  I've got another thread on here but no VM reply.
Fed up now, time to start looking for new supplier!
Good luck, I hope your issue gets resolved.
  • 11
Message 12 of 17
Hi Garry,
I had a call from one of the engineers this afternoon to let me know that theres a fault in the area but may take a few days to get sorted.
going to be a right pain.
no hope calling the helpline tho.
  • 11
Message 13 of 17
Still no internet, it is pretty much unusable,
Can anyone give an update ?? Can i get a tec visit to sort this out ??
No idea what im paying for here as service is shocking at the time we all need it the most
  • 11
Message 14 of 17
  • 11
Message 15 of 17
1402750000440256 qam25
21867500008.640256 qam7
31947500008.340256 qam8
4202750000840256 qam9
52107500007.540256 qam10
62187500007.140256 qam11
7226750000740256 qam12
82347500006.840256 qam13
92427500006.540256 qam14
102507500006.140256 qam15
11258750000640256 qam16
12266750000640256 qam17
132747500005.640256 qam18
142827500005.440256 qam19
152907500005.440256 qam20
162987500005.440256 qam21
173067500005.140256 qam22
18314750000540256 qam23
193227500004.840256 qam24
20410750000440256 qam26
214187500003.740256 qam27
224267500003.940256 qam28
234347500003.540256 qam29
24442750000340256 qam30
1Locked40.940
2Locked40.9100
3Locked40.380
4Locked40.9150
5Locked40.990
6Locked40.9960
7Locked40.360
8Locked40.360
9Locked40.9100
10Locked40.990
11Locked40.380
12Locked40.380
13Locked40.390
14Locked40.91150
15Locked40.340
16Locked40.370
17Locked40.3110
18Locked40.980
19Locked40.3190
20Locked40.3180
21Locked40.3170
22Locked40.3200
23Locked40.3170
24Locked40.360
1257998164.125512016 qam90
2326003574.175512016 qam89
  • 19.64K
  • 1.72K
  • 4.29K
Message 16 of 17
can you post the network log, the downstream power levels are rather high on certain channels, but shouldn't be on qam16 for the upstream, possible network side issue.
  • 11
Message 17 of 17
01/04/2020 22:04:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 22:01:49noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 21:15:46Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 19:56:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 18:42:29Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 18:38:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 17:45:46Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 17:20:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 15:05:9Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 12:25:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 11:38:19Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 17:35:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 17:32:26Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 17:00:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 16:59:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 16:00:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 15:56:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 15:55:35Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 14:23:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2020 14:21:44noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
