on 03-08-2022 21:24
Hello
I've been having issues with my upload never being consistent for over a month now. I've had multiple engineers and technicians to my home nearly every week. I need my upload to always be high in order to work from home and I've been unable to do so because of the persisting issue.
My internet package is Gig1 Fibre Broadband, I have a hub 5, my download is fine, but at times my upload will drop below the promised minimum and even lower into 0.90 and lower. I am connected directly into the hub via ethernet cable I should also mention.
I need this issue fixed and this is my next best bet to try and get some help while I wait through the week for my next engineer to arrive next week.
Here are the usual bits of info to share from what I've seen on the forums. Any help would be appreciated. Cheers.
Feel free to ask for any other needed information.
1 | 46200000 | 39 | 5120 | QAM 16 | 1 |
2 | 39400000 | 38.8 | 5120 | QAM 16 | 2 |
3 | 32600000 | 38.3 | 5120 | QAM 16 | 3 |
4 | 25800000 | 37.8 | 5120 | QAM 16 | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
SFIDMax Traffic RateMax Traffic BurstMin Traffic Rate
8836 |
1230000450 bps |
42600 bytes |
0 bps |
Primary Upstream Service Flow
SFIDMax Traffic RateMax Traffic BurstMin Traffic RateMax Concatenated BurstScheduling Type
8835 |
55000270 bps |
42600 bytes |
0 bps |
42600 bytes |
Best Effort |
1 | 331000000 | 2.1 | 40 | QAM 256 | 25 |
2 | 139000000 | -1.3 | 38 | QAM 256 | 1 |
3 | 147000000 | -1 | 38 | QAM 256 | 2 |
4 | 155000000 | 0.8 | 39 | QAM 256 | 3 |
5 | 163000000 | 0.7 | 39 | QAM 256 | 4 |
6 | 171000000 | 0.5 | 39 | QAM 256 | 5 |
7 | 179000000 | 0.3 | 39 | QAM 256 | 6 |
8 | 187000000 | 0.1 | 39 | QAM 256 | 7 |
9 | 195000000 | 0.2 | 39 | QAM 256 | 8 |
10 | 203000000 | 0.4 | 39 | QAM 256 | 9 |
11 | 211000000 | 0.8 | 39 | QAM 256 | 10 |
12 | 219000000 | 1 | 39 | QAM 256 | 11 |
13 | 227000000 | 1 | 39 | QAM 256 | 12 |
14 | 235000000 | 1.1 | 40 | QAM 256 | 13 |
15 | 243000000 | 1 | 40 | QAM 256 | 14 |
16 | 251000000 | 0.9 | 39 | QAM 256 | 15 |
17 | 259000000 | 1.1 | 40 | QAM 256 | 16 |
18 | 267000000 | 1.1 | 40 | QAM 256 | 17 |
19 | 275000000 | 1.3 | 40 | QAM 256 | 18 |
20 | 283000000 | 1.5 | 40 | QAM 256 | 19 |
21 | 291000000 | 1.6 | 40 | QAM 256 | 20 |
22 | 299000000 | 1.8 | 40 | QAM 256 | 21 |
23 | 307000000 | 1.9 | 40 | QAM 256 | 22 |
24 | 315000000 | 2 | 40 | QAM 256 | 23 |
25 | 323000000 | 2 | 40 | QAM 256 | 24 |
26 | 339000000 | 2.4 | 40 | QAM 256 | 26 |
27 | 347000000 | 2.5 | 40 | QAM 256 | 27 |
28 | 355000000 | 2.6 | 40 | QAM 256 | 28 |
29 | 363000000 | 2.6 | 40 | QAM 256 | 29 |
30 | 371000000 | 2.7 | 40 | QAM 256 | 30 |
31 | 379000000 | 2.7 | 40 | QAM 256 | 31 |
1 | Locked | 40 | 0 | 2 |
2 | Locked | 38 | 0 | 8 |
3 | Locked | 38 | 0 | 4 |
4 | Locked | 39 | 0 | 3 |
5 | Locked | 39 | 0 | 4 |
6 | Locked | 39 | 0 | 2 |
7 | Locked | 39 | 0 | 5 |
8 | Locked | 39 | 0 | 3 |
9 | Locked | 39 | 0 | 3 |
10 | Locked | 39 | 0 | 1 |
11 | Locked | 39 | 0 | 2 |
12 | Locked | 39 | 0 | 1 |
13 | Locked | 39 | 0 | 5 |
14 | Locked | 40 | 0 | 2 |
15 | Locked | 40 | 0 | 3 |
16 | Locked | 39 | 0 | 2 |
17 | Locked | 40 | 0 | 0 |
18 | Locked | 40 | 0 | 0 |
19 | Locked | 40 | 0 | 1 |
20 | Locked | 40 | 0 | 1 |
21 | Locked | 40 | 0 | 1 |
22 | Locked | 40 | 0 | 2 |
23 | Locked | 40 | 0 | 3 |
24 | Locked | 40 | 0 | 0 |
25 | Locked | 40 | 0 | 7 |
26 | Locked | 40 | 0 | 0 |
27 | Locked | 40 | 0 | 5 |
28 | Locked | 40 | 0 | 2 |
29 | Locked | 40 | 0 | 3 |
30 | Locked | 40 | 0 | 0 |
31 | Locked | 40 | 0 | 3 |
on 04-08-2022 00:49
I will also provide a BQM when I can
on 04-08-2022 21:02
on 07-08-2022 17:03
Hey Joshbisso, thank you for reaching out and I am sorry to hear about your connection issues.
I can also see you have been speaking to the team and you have someone coming out shortly to look into this for you.
I have also run some tests and this resulted in with needing someone to come and look at it.
Please can you keep me updated on how this visit goes. Thanks
Matt - Forum Team
New around here?
on 07-08-2022 17:14
it's been like this for a month and hasn't been fixed by repeated engineer visits so I expect this fixed.
on 10-08-2022 08:07
Thank you for that information Joshbisso.
What have the engineer advised upon their visits? When they have left has the service been working?
^Martin
on 10-08-2022 12:14
They have confirmed that the issue is a network issue and my home connections are fine. You need to fix my cabinet.
on 10-08-2022 12:20
They’ve listed it as a P4 network referral and have said it should be fixed in 2-3 days. I expect this fixed as soon as possible as it’s been this way for over a month.
on 12-08-2022 12:35
Thank you for letting us know @Joshbisso
As it has been a few days how are things looking for you at the moment?
on 12-08-2022 12:55
The issue is still not fixed as I’m waiting for the network engineer to fix the box on my street.
