Alex_gregory_uk
  • 10
Message 1 of 10
Upload speed low for last month or so
For the last month or so I've gone from 32mb upload to around 15mb upload. I use the router in modem only mode with a decent router attached. I've hard wired my laptop to the router. I've restarted all equipment and still see consistent 300+mb download and around 15mb upload.
Any help would be appreciated.
Alex
Tags (1)
Alex_gregory_uk
  • 10
Message 2 of 10
Re: Upload speed low for last month or so
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
298750000
8
37
256 qam
21
2
202750000
6.5
37
256 qam
9
3
210750000
6.5
37
256 qam
10
4
218750000
6.5
37
256 qam
11
5
226750000
6.8
37
256 qam
12
6
234750000
6.9
37
256 qam
13
7
242750000
6.8
37
256 qam
14
8
250750000
6.8
37
256 qam
15
9
258750000
6.8
37
256 qam
16
10
266750000
6.9
37
256 qam
17
11
274750000
7
37
256 qam
18
12
282750000
7.4
37
256 qam
19
13
290750000
7.6
37
256 qam
20
14
306750000
8
38
256 qam
22
15
314750000
7.6
37
256 qam
23
16
322750000
7.4
37
256 qam
24
17
330750000
7.8
38
256 qam
25
18
370750000
9.1
38
256 qam
26
19
378750000
9.5
38
256 qam
27
20
386750000
9
38
256 qam
28
21
394750000
9
38
256 qam
29
22
402750000
9
38
256 qam
30
23
410750000
9
38
256 qam
31
24
418750000
9.1
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
182014
0
2
Locked
37.3
715130
0
3
Locked
37.3
782650
0
4
Locked
37.3
731327
0
5
Locked
37.6
567570
0
6
Locked
37.6
496813
0
7
Locked
37.6
519808
0
8
Locked
37.3
531726
0
9
Locked
37.6
558475
0
10
Locked
37.3
447304
0
11
Locked
37.6
364155
0
12
Locked
37.6
280402
0
13
Locked
37.6
214712
0
14
Locked
38.6
131750
0
15
Locked
37.6
158569
0
16
Locked
37.6
212224
0
17
Locked
38.6
158895
0
18
Locked
38.9
42585
0
19
Locked
38.6
39688
0
20
Locked
38.9
50361
0
21
Locked
38.6
55248
0
22
Locked
38.9
46753
0
23
Locked
38.6
51139
0
24
Locked
38.9
36756
0
Alex_gregory_uk
  • 10
Message 3 of 10
Upstream shows
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
36.8
5120
64 qam
7
2
39400009
37
5120
64 qam
6
3
46200075
37.5
5120
64 qam
5
4
25800107
36.5
5120
64 qam
8
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
2
0
4
ATDMA
0
0
2
0
Log shows
Time
Priority
Description
29/01/2021 11:07:39
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 22:20:18
critical
25/01/2021 21:49:31
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 12:34:12
critical
23/01/2021 14:55:59
notice
21/01/2021 04:38:30
Error
18/01/2021 17:31:17
critical
17/01/2021 16:38:29
Error
01/01/1970 00:02:9
critical
14/01/2021 05:32:45
notice
SW download Successful - Via NMS
14/01/2021 05:31:22
notice
SW Download INIT - Via NMS
14/01/2021 03:41:21
Error
10/01/2021 20:23:3
critical
03/01/2021 15:41:20
Error
31/12/2020 23:18:28
critical
31/12/2020 03:41:19
Error
29/12/2020 23:50:13
critical
27/12/2020 15:41:18
Error
26/12/2020 01:32:10
critical
13/12/2020 15:41:16
Error
Alex_gregory_uk
  • 10
Message 4 of 10
Is there anyone that can assist? I'm still seeing the same issue.
Cheers
Alex
conman33158
  • 873
  • 81
  • 123
Superfast
Message 5 of 10
Your router stats are all fine.
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Make sure Hub is in router mode
  4. Disconnect all other Ethernet cables when running the test
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
Alex_gregory_uk
  • 10
Message 6 of 10
Hi there,
Sorry for the delay in getting back to you. Here is the link to the Live Graph. I'll connect to the router direct later today.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f13c11d6d4fe593383c808c519e8a9ef37...
Many thanks
Alex
conman33158
  • 873
  • 81
  • 123
Superfast
Message 7 of 10
Did you do the test I asked? You need to have your Virgin Hub in router mode while doing the test so we can determine if your third party router is the problem or Virgin.
Also you need to go into your firewall when you go back to modem mode and check "Yes" or "Allow" on Respond ICMP Echo (ping) Request from WAN it might be worded differently on your router as you never said which router you are using, you need to set this to let the BQM populate properly 🙂
Alex_gregory_uk
  • 10
Message 8 of 10
Apologies, I've just run the test you requested and the figures are slightly better but not the 30 megs it should be. I'm using a hub 3. My router that I use is a TP Link AC5400X.
Download: 385.59mb
Upload: 18.68mb
It's still in Router mode with only my laptop plugged in. Do I need to leave it this way or can I change it back to Modem and plug my router back in?
Alex
conman33158
  • 873
  • 81
  • 123
Superfast
Message 9 of 10
That's fine mate, you can change it back but just make sure you have ICMP ping enabled in your TP Link AC5400X to let the BQM through 🙂
I've just noticed that your power levels are a bit low on your upload streams which could be the cause of your problem. This would need an engineer to put right. Best to ring VM on or just after 8am or alternatively you can wait here for a Virgin staff member to pick it up, typically between 5-10 days, sometimes sooner, sometimes later depending on how busy they are.
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
36.8
5120
64 qam
7
2
39400009
37
5120
64 qam
6
3
46200075
37.5
5120
64 qam
5
4
25800107
36.5
5120
64 qam
8
Alex_gregory_uk
  • 10
Message 10 of 10
That's great. Thanks. I've put it back to Modem mode and plugged my TP Link back in. I've enabled "Allow pings from Wan port" so hopefully BQM will start working.
I'll see if a Virgin staff member picks up on here and if not will ring VM next week.
