mlewis
  • 30
Message 1 of 35
Upload speed keeps dropping to 1Mbit and less
Let me start by saying yes all connections have been checked the device has been restarted and reset. connected via a cable. and this happen intermittently.
Monday I had the same issue, yesterday was fine now again the issue is back
PING ms  DOWNLOAD Mbps 386.38  UPLOAD Mbps 1.45
My normal upload speed is around 35mbit
Area reference14
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 35
Re: Upload speed keeps dropping to 1Mbit and less
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
mlewis
  • 30
Message 3 of 35
11390000001.938256 qam1
21470000001.738256 qam2
31550000001.738256 qam3
41630000001.538256 qam4
51710000001.438256 qam5
61790000001.238256 qam6
7187000000137256 qam7
81950000001.238256 qam8
92030000001.238256 qam9
102110000001.237256 qam10
112190000001.237256 qam11
122270000001.437256 qam12
13235000000137256 qam13
142430000000.738256 qam14
152510000000.738256 qam15
162590000000.738256 qam16
172670000000.737256 qam17
182750000000.737256 qam18
192830000000.737256 qam19
202910000000.537256 qam20
212990000000.537256 qam21
223070000000.936256 qam22
233150000001.536256 qam23
24323000000236256 qam24
1Locked38.63840
2Locked38.93230
3Locked38.93200
4Locked38.94270
5Locked38.95520
6Locked38.67010
7Locked37.69810
8Locked38.99190
9Locked38.610380
10Locked37.610700
11Locked37.314050
12Locked37.313760
13Locked37.617070
14Locked38.616350
15Locked38.617810
16Locked38.619220
17Locked37.619220
18Locked37.320550
19Locked37.620230
20Locked37.620110
21Locked37.323850
22Locked36.618920
23Locked36.617770
24Locked36.313560
mlewis
  • 30
Message 4 of 35
1603001614.525512064 qam1
2394002014.35512064 qam4
3461998294.4512064 qam3
4537000004.5512064 qam2
3ATDMA0000
4ATDMA0000
mlewis
  • 30
Message 5 of 35
01/01/1970 00:01:40Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:9criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:37:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:36:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 13:17:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
mlewis
  • 30
Message 6 of 35
Please note the logs are from me rebooting and checking all the connections from the modem, splitter and the wall.
Services normally have zero issues all kit has been in place and working for some time with out issue.
mlewis
  • 30
Message 7 of 35
Latest speed tests :   386.51Mbit  Down   1.41 Upload  latency 9ms
testing on speedtest.net to VM Brentford
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 35
Don't forget the 'Live Link' to your BQM.
mlewis
  • 30
Message 9 of 35
MY BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 35
@mlewis wrote:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d7407464f4f979c40c39c899875d2306d9...
404 - Page Not Found
