codebykev
  • 6
Upload speed issues -
Herro,
The first post, i thought i sent a post last night but hey-ho it's possible it was lost in transit.
This morning it looks like you've seen there is an issue. I figured I'd supply some data, plus ask for some advice.
Area affected 20
Symptoms: upload speed dropping out for extended periods to < 1Mbs , the upload would be fine, 200 nearly but then drop down to half after 5 seconds (could just be traffic shaping that one - bursts to download small files etc).
This morning the speed tests are more positive BUT real-world testing of zoom showing I'm suffering network issues. I can hear them and see them fine but they complain I'm freezing and losing audio, which marries to last nights analysis.
I setup a monitor  https://www.thinkbroadband.com/broadband/monitoring/quality/share/c655a9819c83f533b998394497d9294129...
My network stats are
My Broadband Ping - Home
13307500002.238256 qam25
22587500002.740256 qam16
32667500002.740256 qam17
42747500002.539256 qam18
52827500002.740256 qam19
62907500002.538256 qam20
72987500002.438256 qam21
83067500002.238256 qam22
93147500002.238256 qam23
103227500002.238256 qam24
11370750000238256 qam26
123787500001.738256 qam27
133867500001.738256 qam28
143947500001.738256 qam29
154027500001.538256 qam30
164107500001.540256 qam31
174187500001.740256 qam32
184267500001.540256 qam33
194347500001.538256 qam34
204427500001.740256 qam35
214507500001.440256 qam36
224587500001.540256 qam37
234667500001.240256 qam38
24474750000140256 qam39
1Locked38.980
2Locked40.390
3Locked40.360
4Locked39.870
5Locked40.3110
6Locked38.970
7Locked38.980
8Locked38.970
9Locked38.970
10Locked38.6120
11Locked38.9100
12Locked38.970
13Locked38.9110
14Locked38.9140
15Locked38.970
16Locked40.360
17Locked40.370
18Locked40.380
19Locked38.9110
20Locked40.3100
21Locked40.390
22Locked40.380
23Locked40.370
24Locked40.340
1326000003.7039999999999997512064 qam5
2394000003.7039999999999997512064 qam4
3462000003.7039999999999997512064 qam3
4537000003.804512064 qam2
3ATDMA0000
4ATDMA0000
My question is, how do i interpret these tables and marry that to the monitor showing bad latency and packet loss.
Also is that monitor indicative of a network problem... 40% packet loss feels bad... 😄
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Upload speed issues -
That BQM looks like someone has switched off noise on the line.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK you will need to contact VM.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Martin_N
  • 5.54K
  • 232
  • 316
Hi codebykev,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the broadband issue you're having.
I have taken a look on our side and I am unable to see anything that could be affecting this.
Can you confirm that all the cables on your hub are tightly secure?
Can you confirm if you're continuing to have this issue?
^Martin
