Hi all,
I've had this intermittent problem occur twice now and need to know what's going on as I'm currently trying to work from home.
On Friday the 05-JUN-2020 is when it first occurred and it only lasted about 1-2 hours and went away after resetting the hub twice. It then didn't happen over the weekend and was fine this morning also, but now its been down since midday today (so 7 hours as of posting this).
My download speed is still very fast, 373.9Mbps, but my upload speed is practically non-existent at below 0.1Mbps. This as you can imagine is causing a lot of issues.
Now I've tried all the classic fixes. The virgin media status says there are no known issues and when i do the test on their site it says all is fine. I then do a speed test and get the same results roughly every time. Three times today I've powered down the hub, left it for 15 minutes and then powered it back on. No fix. The front light is pink as I am running in modem mode and no other lights are showing. The hub is then connected directly to my PC as well as a Deco mesh wifi network system, BOTH of which show the same issue. All cables are checked and secure.
Any ideas on how to fix the issue?
