JewelKnightJess
  • 29
Message 1 of 30
Upload speed has gone very slow
Hello,
We do livestreaming on Twitch with Virgin Media and we're on the 200mb package - normally the upload speed is a solid 20mb and does the job wonderfully but since yesterday it's been really bad for us. I was unable to stream much today as it tanked as low as 0.7mb according to speed tests at times, and its peaking at about 7mb at the moment.
I stream from my Ethernet connected PC normally without issue. Can anyone suggest anything?
Here's my info from Check Router Status:
227000000
Locked
Ranged Upstream Channel (Hz)
39400727
Locked
Provisioning State
Online
1Locked38.640
2Locked40.300
3Locked40.300
4Locked38.960
5Locked40.330
6Locked38.940
7Locked40.300
8Locked40.340
9Locked40.350
10Locked38.960
11Locked40.340
12Locked38.940
13Locked40.350
14Locked38.9180
15Locked40.300
16Locked40.350
17Locked38.950
18Locked40.340
19Locked38.650
20Locked37.300
21Locked35.7190
22Locked37.660
23Locked38.640
24Locked38.900
13940072741.3512016 qam2
22580035640.5512016 qam4
33260046941512016 qam3
44619998541512064 qam1
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID378316
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID378315
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
JewelKnightJess
  • 29
Message 2 of 30
Re: Upload speed has gone very slow
12270000005.938256 qam12
2219000000640256 qam11
32350000005.640256 qam13
42430000005.638256 qam14
52510000005.840256 qam15
62590000005.838256 qam16
72670000005.840256 qam17
8275000000640256 qam18
92830000006.140256 qam19
10291000000638256 qam20
112990000006.140256 qam21
123070000006.138256 qam22
133150000006.140256 qam23
143230000006.138256 qam24
153310000006.340256 qam25
163710000005.340256 qam26
173790000005.338256 qam27
183870000005.440256 qam28
19395000000538256 qam29
204030000002.237256 qam30
21411000000-235256 qam31
224190000002.937256 qam32
234270000004.838256 qam33
244350000005.138256 qam34
1Locked38.640
2Locked40.300
3Locked40.300
4Locked38.960
5Locked40.330
6Locked38.940
7Locked40.300
8Locked40.340
9Locked40.350
10Locked38.960
11Locked40.340
12Locked38.940
13Locked40.350
14Locked38.9180
15Locked40.300
16Locked40.350
17Locked38.950
18Locked40.340
19Locked38.650
20Locked37.300
21Locked35.7190
22Locked37.660
23Locked38.640
24Locked38.900
JewelKnightJess
  • 29
Message 3 of 30
04/12/2020 21:15:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 21:15:8Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 17:21:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 17:21:20Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 02:20:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2020 22:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2020 01:15:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2020 10:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 11:34:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 22:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 10:11:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 10:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 23:34:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 22:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 15:14:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 22:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 05:35:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 10:35:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 15:55:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 23:39:9Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gitty
  • 123
  • 32
Up to speed
Message 4 of 30
Something is impacting both your downstream and your upstream frequencies (the may or may not be related). The fault can either be in your home or outside.
jpeg1
  • 5.43K
  • 284
  • 895
Superstar
Message 5 of 30
Three of your upstream channels have dropped from 64QAM to 16QAM.  This would certainly explain the drop in uplink speed.  Try rebooting your Hub. If this doesn't resolve itself fairly soon you will need to call it in as a fault.
JewelKnightJess
  • 29
Message 6 of 30
I did reboot a few times over the course of the day but those numbers have stayed low.
Thanks for your help. I'll see what it looks like tomorrow morning...
JewelKnightJess
  • 29
Message 7 of 30
Update: The modulation said 64qam this morning on all 4 channels, but as of 8pm tonight it's showing like this:
13940037041.3512016 qam2
22580008940.5512064 qam4
33260048941512016 qam3
44620002341512064 qam1
So it's sort of fluctuating as far as I can tell. Should I request an engineer?
jpeg1
  • 5.43K
  • 284
  • 895
Superstar
Message 8 of 30
I would report it as a fault, if you can get through on the support line.
Tell them (if they can understand) that (1) the upstream modulation keeps changing and (2) that there is an 8dB variation between downstream channels. Both of these indicate something wrong very locally.
You might find better results if you wait for a VM person to see your post here.
Incidentally, do check that your local coax connections are still secure, as a loose connection indoors could produce these faults.
JewelKnightJess
  • 29
Message 9 of 30
13939992341.3512016 qam2
22579985940.5512064 qam4
33259984641512016 qam3
44619994141512064 qam
1
That's how things look tonight. If a VM person can advise I'd really appreciate it as its hitting our ability to do our livestreams which is an income source for us.
I've checked the connections, they are all finger-tight indoors here. I am in a flat so I have no idea what the outside situation looks like, wouldn't know what I was looking at.
Djamberd
  • 12
Message 10 of 30
Am in the same situation streaming on Twitch 💗
