Yanti
Just joined
Upload speed dropped to almost zero
My upload speed has dropped almost to zero, download is perfectly fine.
Tried rebooting everything with no luck.
Thanks in advance for any help!
Hub stats as follows:
DOWNSTREAM:
12590000001.540256 qam16
2139000000440256 qam1
31470000003.538256 qam2
4155000000338256 qam3
51630000002.938256 qam4
61710000002.538256 qam5
71790000002.240256 qam6
8187000000238256 qam7
9195000000240256 qam8
10203000000238256 qam9
112110000001.738256 qam10
122190000001.740256 qam11
132270000001.538256 qam12
142350000001.538256 qam13
152430000001.538256 qam14
162510000001.540256 qam15
172670000001.540256 qam17
182750000001.238256 qam18
192830000001.538256 qam19
202910000002.238256 qam20
212990000001.238256 qam21
223070000000.538256 qam22
23315000000038256 qam23
243230000000.738256 qam24
1Locked40.960
2Locked40.370
3Locked38.9260
4Locked38.9360
5Locked38.9160
6Locked38.960
7Locked40.370
8Locked38.950
9Locked40.360
10Locked38.950
11Locked38.950
12Locked40.360
13Locked38.950
14Locked38.670
15Locked38.950
16Locked40.360
17Locked40.350
18Locked38.960
19Locked38.940
20Locked38.910
21Locked38.940
22Locked38.960
23Locked38.900
24Locked38.650
UPSTREAM:
14619927949512016 qam3
23939987248.8512016 qam4
35370039649.3512016 qam2
46030013749512016 qam1
Upstream bonded channels:
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
1ATDMA0020
2ATDMA0050
3ATDMA0020
4ATDMA0020
Network Log:
16/12/2020 15:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2020 15:14criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 11:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/12/2020 09:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 21:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 11:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 17:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/12/2020 10:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 16:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 10:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 23:05criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 22:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 12:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 08:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2020 22:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 02:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2020 21:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/1970 09:12ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/1970 09:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/1970 04:09ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Upload speed dropped to almost zero
Your Upstream Modulations are all too low, they should be at 64 QAM.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
UPSTREAM:
Yanti
Just joined
Live link to Broadband Quality Monitor
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f0d9b1689e8469445affb697875a8b1e96329dba
