on 26-08-2023 18:29
Hi, I have a problem with the upload speed as I was getting a nice constant 110Mb/s on average with HUB 5 since they rolled out double upload speeds - now my speeds are worse than my old 50Mb/s.Over the past 3 days, I've restarted the router and seen no improvement. My package is 1 Gig and have been on this for a number of years now.
I then checked with Virgin's status checker, which says they detected an issue. No clue as to what that may entail, and status checker says if I run the test in another 5 hours with the same issue, they will help arrange to get someone to check it out.
But, I want to make sure the issue is an actual fault not of my own so I avoid any charges as I can't afford that and want to ensure I carry out any tests to rule out something else, or if Virgin staff here on the forum could look at my line or any issues in my area, please? I know it can take them some time to read these messages.
Downloads are good but uploads are a lot slower on router and to my PC:
I last restarted my router yesterday so the build-up of errors will be low. Not sure about the rest:
1 | 306000000 | 5.3 | 39 | QAM 256 | 22 |
2 | 138000000 | 7.1 | 39 | QAM 256 | 1 |
3 | 146000000 | 6.8 | 39 | QAM 256 | 2 |
4 | 154000000 | 6.7 | 39 | QAM 256 | 3 |
5 | 162000000 | 6.3 | 39 | QAM 256 | 4 |
6 | 170000000 | 6 | 39 | QAM 256 | 5 |
7 | 178000000 | 5.9 | 39 | QAM 256 | 6 |
8 | 186000000 | 5.8 | 39 | QAM 256 | 7 |
9 | 194000000 | 5.9 | 39 | QAM 256 | 8 |
10 | 202000000 | 5.8 | 39 | QAM 256 | 9 |
11 | 210000000 | 5.8 | 39 | QAM 256 | 10 |
12 | 218000000 | 5.6 | 39 | QAM 256 | 11 |
13 | 226000000 | 5.4 | 39 | QAM 256 | 12 |
14 | 234000000 | 5.2 | 39 | QAM 256 | 13 |
15 | 242000000 | 5 | 39 | QAM 256 | 14 |
16 | 250000000 | 4.9 | 39 | QAM 256 | 15 |
17 | 258000000 | 5 | 39 | QAM 256 | 16 |
18 | 266000000 | 5 | 39 | QAM 256 | 17 |
19 | 274000000 | 4.6 | 39 | QAM 256 | 18 |
20 | 282000000 | 4.6 | 39 | QAM 256 | 19 |
21 | 290000000 | 4.9 | 39 | QAM 256 | 20 |
22 | 298000000 | 5.2 | 39 | QAM 256 | 21 |
23 | 314000000 | 5.3 | 39 | QAM 256 | 23 |
24 | 322000000 | 5.4 | 39 | QAM 256 | 24 |
25 | 330000000 | 5.5 | 40 | QAM 256 | 25 |
26 | 338000000 | 5.9 | 39 | QAM 256 | 26 |
27 | 346000000 | 6 | 40 | QAM 256 | 27 |
28 | 354000000 | 6 | 40 | QAM 256 | 28 |
29 | 362000000 | 6.1 | 40 | QAM 256 | 29 |
30 | 370000000 | 6.2 | 40 | QAM 256 | 30 |
31 | 378000000 | 6.1 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 1 | 0 |
2 | Locked | 39 | 4 | 0 |
3 | Locked | 39 | 0 | 0 |
4 | Locked | 39 | 2 | 0 |
5 | Locked | 39 | 0 | 0 |
6 | Locked | 39 | 1 | 0 |
7 | Locked | 39 | 0 | 0 |
8 | Locked | 39 | 1 | 0 |
9 | Locked | 39 | 0 | 0 |
10 | Locked | 39 | 0 | 0 |
11 | Locked | 39 | 0 | 0 |
12 | Locked | 39 | 0 | 0 |
13 | Locked | 39 | 1 | 0 |
14 | Locked | 39 | 0 | 0 |
15 | Locked | 39 | 0 | 0 |
16 | Locked | 39 | 0 | 0 |
17 | Locked | 39 | 0 | 0 |
18 | Locked | 39 | 0 | 0 |
19 | Locked | 39 | 1 | 0 |
20 | Locked | 39 | 0 | 0 |
21 | Locked | 39 | 1 | 0 |
22 | Locked | 39 | 0 | 0 |
23 | Locked | 39 | 0 | 0 |
24 | Locked | 39 | 1 | 0 |
25 | Locked | 40 | 0 | 0 |
26 | Locked | 39 | 0 | 0 |
27 | Locked | 40 | 0 | 0 |
28 | Locked | 40 | 0 | 0 |
29 | Locked | 40 | 0 | 0 |
30 | Locked | 40 | 0 | 0 |
31 | Locked | 40 | 0 | 0 |
0 | 49600000 | 45.3 | 5120 | QAM 64 | 9 |
1 | 43100000 | 44.8 | 5120 | QAM 64 | 10 |
2 | 36600000 | 45 | 5120 | QAM 64 | 11 |
3 | 30100000 | 44.8 | 5120 | QAM 64 | 12 |
4 | 23600000 | 43.8 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
General Configuration
Allowed |
3 |
Enabled |
3.1 |
ewrkldJKDHSUBsgvca69834ncxv98 |
5411 |
128000 bps |
4000bytes |
0 bps |
20936 |
1200000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
5348 |
128000 bps |
4000bytes |
0 bps |
1522bytes |
Best Effort |
20933 |
110000274 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
26-08-2023 01:25:19 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:25:19 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:25:16 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
26-08-2023 01:25:10 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:25:10 | warning | Dynamic Range Window violation |
26-08-2023 01:25:10 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:25:10 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:25:05 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:24:53 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:24:51 | notice | Honoring MDD; IP provisioning mode = IPv4 |
26-08-2023 01:24:41 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 01:24:28 | critical | Cable Modem Reboot due to power button reset |
26-08-2023 00:14:21 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2023 00:14:09 | critical | Cable Modem Reboot due to power button reset |
13-08-2023 15:56:31 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
13-08-2023 15:56:19 | critical | Cable Modem Reboot due to power button reset |
31-07-2023 00:08:26 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
31-07-2023 00:08:14 | critical | Cable Modem Reboot due to power button reset |
21-07-2023 05:03:08 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-07-2023 05:03:07 | critical | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-07-2023 04:06:00 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-07-2023 04:05:48 | critical | Cable Modem Reboot due to power button reset |
26-08-2023 20:55 - edited 26-08-2023 20:56
How many times a day do you test your speed? How did you know you speed was slow to run a speed test?
can you test speed to a upload site with a big file?
on 27-08-2023 00:53
I am unsure about the questions based on the information I provided, do you have any immediate observations based upon my line stats, ie this one is new to me:
I will try to answer questions to get to the bottom of this.
I do not constantly test my speed. This is not a habit of mine. I know what download speeds I get from downloading from Steam because it tells you, but here the upload issue was discovered because my weekly Acronis backup was showing slower than normal speeds as noted in OP for now 4 days in a row and you tend to notice that, the time to upload tripled. Same with Amazon photos, I came back from the summer holidays and had a lot of good photos to upload from my PC that I had to leave to run overnight.
How I know the speeds in general is just to open TaskMan (CTRL+SHIFT+ESC) and see my upload max out at 35Mb/s on any of the upload services I have. This includes testing with Speedtest.net and SamKnows. What is odd is that my upload speeds sometimes start out at around 80Mb/s but quickly drops towards 30Mb/s. I'm also using a Cat 7 cable, I had been using Cat 6A on the old HUB 4 without issue so I tested that and speeds didn't change, also tested with Cat 5E and CAT 5.
Then checking with Virgin's status checker that checks your hub. That now says:
"We need to send a technician to fix things Thanks for your patience. As there’s still an issue, we need to send one of our technicians to visit you."
I'm not too keen on booking an appointment until I have some idea what is causing the issue, doesn't help the issue with slow uploads isn't always consistent either. I would like to share upload results that are reliable and consistent and unsure about this, ie sites that directly upload and don't throttle.
on 27-08-2023 01:10
I've added a live BQM link to my signature, and here is a screenshot of the speedtest I've just ran of my upload behaviour starting at 31.1Mb/s before coming down to 10Mbps, averages out at 18.9Mb/s and that seems to match my experience of just using the internet and feeling how long it takes to upload:
on 27-08-2023 10:55
maybe lots of people in your area are uploading?
on 27-08-2023 11:06
The upstream channels look fine. Check for a local fault via 0800 561 0061.
on 27-08-2023 23:06
Thanks for that suggestion Client62 and for checking over the line stats.
I phoned that number to check the local status. Said they were aware of an issue in my area affecting my TV, broadband and telephone services. Continues to say they are still working on the issue (today is day 5), and because it is a complex issue, says it will take longer than expected to fix.
From the information I had to find out, there is some issue with my area causing poor services. I wasn't provided with an option to be informed of when they will fix the issue.
I did a check again with the website status page and it has changed. Now states: "Looks like there are issues in your postcode affecting your services. There’s a broadband issue in your area and our technicians are on the case to fix things. Check back here at any time for updates."
on 30-08-2023 08:24
Hey SMiThaYe,
Welcome back to the community and thanks for taking the time to post.
I’m sorry to hear of the issues that you’re having with your connection at the moment. I have looked into this and can see that the area issue that you experienced over the last week has now been resolved. Are you still having issues at the moment?
Kind Regards,
Steven_L
on 30-08-2023 11:39
Hi Steven_L,
Finally, the problem with my uploads has improved. I will add that I'm far from happy with Virgin regularly going down completely and declining services. CityLink is laying cables in my area and I will be glad to move to a reliable service provider when that service becomes available, as I've been dealing with this inconvenience with Virgin since it was installed in 2018.
I do have some feedback on whatever work was being done: in tests I noted uploads go to just above 100, averaging 101Mb/s uploads on thinkbroadband, samknows, speedtest.net. I often used to see it between 110-112Mb/s. My ping has increased from 16ms to 36ms download / 59ms! upload (via those test sites I mentioned previously). Above 30ms I have lag issues with GeForce NOW and 40ms during gameplay has been unplayable no matter the time of day. This results in a delay between pressing the key and driving in Cyberpunk 2033 of 2-3 seconds.
I'm hoping the ping comes down but it's been 2.5 days since my upload speed was restored, but as I often misplace my faith with Virgin I'm not holding my breath that will rectify itself. I am obviously disgusted by the service I am receiving, and Virgin can't be happy with the service they are providing.
I await your response on this matter.
on 01-09-2023 17:27
Thank you for updating us @SMiThaYe and I am so sorry to hear that you have been facing issues with Ping though we are glad that the upload is looking better.
Can I ask how things are looking since your last post, as it has been a further few days?
