Upload speed dire
shann0nc
My upload speed is usually 30+. My upload speed drops to below 2, often below 1 in the evenings all of a sudden. This has been an issue that has happened for the last week and it means I can’t stream, stopping me from earning money. It is unusable. I have pinhole reset the router and nothing is working. Used to happen 9pm onwards but has now gotten earlier. Doesn’t come back up until the next morning. Have no idea why I’m being told to write on a forum as if it will fix it. Extremely frustrating.
4 REPLIES 4
Hero
The link below attempts to reveal if speed is lost from the internet to the Hub or from the Hub to your devices.
The results to the Hub should reflect your subscription rate, the speed to the device can be less especially if WiFi is involved.
the upload subscription rate is 35 and I'm getting less than 2, often less than 1 on both Router and Device evening time until the following morning.
Check for ...
Local faults on : 0800 561 0061
Area faults via :  https://my.virginmedia.com/faults/service-status
Hey shann0nc,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having with your upload speeds at the moment, how has your connection been running since you last posted?
Have you checked for any area issues as Client62 advised?
Kind Regards,
Steven_L
