tomcepinnock
  • 5
Message 1 of 10
Upload speed dire..
So we have had VM broadband for many years and 6 months ago we moved 300 metres up the road. This property had VM broadband already when we moved in.
Long story short, our upload speed is dire. Today its been about 0.1Mbps and in fact some of the day it failed to register at all. Download is absolutely fine at approx. 210Mbps.
Virgin Media have replaced the ONU, the fibre between the cabinet and the house and the 'super' hub 3 three times. Nothing has made any difference whatsoever and despite sending multiple engineers nothing has changed and if anything it has gotten worse.
Video calls and screen sharing are impossible, which of course nobody is doing right now!
Just for information, these speeds are achieved via LAN cable and also via mesh WiFi. The speeds are very similar, however the upper limit of about 0.6Mbps achieved via cable.
To add to the complexity the last engineer to come out was jokingly talking about the 10Gig trial which took place round here about 18-24 months ago (not a huge success) which has apparently 'obliterated the upload performance'.
I have just set up a think broadband monitor but I'm a bit stumped as to what to do now. We live miles from the BT exchange and as such they don't present much of a suitable alternative.
Please help! What do I do next?
Tags (1)
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 2 of 10
Re: Upload speed dire..
Can you please upload your router stats and set up a BQM
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
Do NOT log in, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
Do not try to fit everything in one post! You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
tomcepinnock
  • 5
Message 3 of 10
Downstream
13310000000.538256 qam25
22030000002.540256 qam9
32110000002.440256 qam10
42190000002.540256 qam11
52270000002.240256 qam12
62350000002.240256 qam13
72430000001.940256 qam14
82510000001.740256 qam15
92590000001.740256 qam16
102670000001.540256 qam17
112750000001.240256 qam18
122830000001.240256 qam19
13291000000138256 qam20
14299000000138256 qam21
153070000000.740256 qam22
163150000000.538256 qam23
173230000000.740256 qam24
183390000000.738256 qam26
193470000000.740256 qam27
203550000000.438256 qam28
213630000000.740256 qam29
223710000000.438256 qam30
233790000000.538256 qam31
243870000000.540256 qam32
1Locked38.9570
2Locked40.3680
3Locked40.3330
4Locked40.9200
5Locked40.3510
6Locked40.3510
7Locked40.31150
8Locked40.31220
9Locked40.3870
10Locked40.3780
11Locked40.3660
12Locked40.3600
13Locked38.9510
14Locked38.9740
15Locked40.31010
16Locked38.91180
17Locked40.3580
18Locked38.9370
19Locked40.3510
20Locked38.9420
21Locked40.3440
22Locked38.9510
23Locked38.9370
24Locked40.3220
Upstream
13940002842.3512016 qam4
24620012042.3512016 qam3
36029997642512016 qam1
45370000842.3512016 qam2
1ATDMA0050
2ATDMA0020
3ATDMA00100
4ATDMA0010
tomcepinnock
  • 5
Message 4 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID61246
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID61245
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
13/05/2021 10:45:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2021 10:44:59 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/05/2021 10:16:15 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2021 07:31:26 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2021 06:07:5 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/05/2021 19:51:11 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/05/2021 18:07:5 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2021 15:02:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2021 06:07:5 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 19:37:43 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2021 19:03:20 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 10:55:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 10:06:47 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 09:51:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 09:12:38 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 09:03:47 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 08:59:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 08:59:20 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 08:57:10 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/04/2021 08:57:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 5 of 10
1ATDMA0050
2ATDMA0020
3ATDMA00100
4ATDMA0010
Your upload streams are on the wrong modulation and should be 64 QAM plus you have too many T3 Timout errors. This could be a sign of a line fault but you would still need an engineer visit to put right. Best to ring Virgin on or just after 8am on 0345 454 1111 or alternatively you can wait here for a Virgin staff member to pick it up, but unfortunately this will typically be between 5-10 days, sometimes sooner, sometimes later depending on how busy they are. If you decide to call it in it will run through a few automated options and after that ring back again and it should recognise that you have rang previously and then put you in the queue for a Virgin representative 🙂
tomcepinnock
  • 5
Message 6 of 10
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 7 of 10
Yeah, your BQM is also showing packet loss and would indeed need looking into to.
tomcepinnock
  • 5
Message 8 of 10
Thanks - I've had three engineers out - but I've had no success - is there something specific I need to ask for?
Cheers for your help!
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 9 of 10
Not really, just explain what's been happening and hopefully they will get to the bottom of it. Could be anything at this stage, cable replacement, adjustment at the cabinet. Who knows but unfortunately sometimes it can take time and multiple visits to get it narrowed down to a specific problem.
Ashleigh_C
  • 2.83K
  • 112
  • 234
Message 10 of 10
HI @tomcepinnock
Thank you so much for your post and I am so sorry this has been an ongoing issue.
I've had a look into your account and I can see that there do appear to be some issues which would be best investigated by an engineer. I'd be happy to book an appointment for you, I will send you a PM so we can arrange this. Please keep an eye out for the purple envelope in the top right corner of your profile to alert you to a new message.
Thank you.
Ash_C
