forumarchive,nothingtosee,
wiggydave10
  • 61
Message 1 of 25
Upload speed constantly below half of what it should be
We have the 200mbps package, which should result in about 20mbps upload, however we ver y rarely are seeing this, its normally <10mbps.
Is there a reason we might be seeing this? Is there an issue that I can't see?
Regards,
wiggydave10
Details:
Spoiler
Area reference: 22
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12587500004.940256 qam16
21387500006.540256 qam1
31467500006.540256 qam2
41547500006.440256 qam3
51627500006.440256 qam4
61707500006.440256 qam5
71787500006.140256 qam6
81867500006.140256 qam7
91947500005.940256 qam8
102027500005.640256 qam9
112107500005.340256 qam10
122187500005.340256 qam11
13226750000540256 qam12
142347500004.940256 qam13
152427500004.940256 qam14
162507500004.940256 qam15
172667500005.140256 qam17
182747500005.140256 qam18
192827500005.540256 qam19
202907500005.540256 qam20
212987500005.840256 qam21
223067500005.840256 qam22
233147500005.840256 qam23
243227500005.640256 qam24
1Locked40.913720
2Locked40.36270
3Locked40.95170
4Locked40.95410
5Locked40.35440
6Locked40.311770
7Locked40.34370
8Locked40.34680
9Locked40.94260
10Locked40.93810
11Locked40.312690
12Locked40.96340
13Locked40.38300
14Locked40.314010
15Locked40.38650
16Locked40.912500
17Locked40.39540
18Locked40.98220
19Locked40.98560
20Locked40.911330
21Locked40.913430
22Locked40.98560
23Locked40.98830
24Locked40.37810
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1394000183.75512064 qam4
2462000003.775512064 qam3
3326000023.675512064 qam9
4258000523.625512064 qam10
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 25
Re: Upload speed constantly below half of what it should be
How are you connecting Wi-Fi or ethernet cable ?
What is your download speed like ?
wiggydave10
  • 61
Message 3 of 25
Hi @MikeRobbo,
I should have stated, I'm connected via Ethernet cable and the download speed seems pretty solid around 200mbps (which is what i'd expect)
I've kept an eye on the speeds over the past week or so just in case it was a blip for a couple of days, but it seems pretty consistent with 200mbps down, <10mbps up
The area doesn't say there are any issues, and I can't remember what the signal level should be for upload (or the range). I once knew, but can't remember!
Regards,
wiggydave10
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 25
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
wiggydave10
  • 61
Message 5 of 25
@MikeRobbo,
Thanks for the info. I have tightened all the connections, but they all seemed fine.
My BQM
Router stats:
61707500006.540256 qam5
71787500006.340256 qam6
9194750000640256 qam8
112107500005.440256 qam10
122187500005.440256 qam11
1Locked40.313720
2Locked40.36280
3Locked40.35170
4Locked40.95410
5Locked40.35440
6Locked40.311780
7Locked40.94370
8Locked40.34680
9Locked40.94260
10Locked40.93810
11Locked40.312690
12Locked40.36340
13Locked40.38300
14Locked40.914020
15Locked40.38660
16Locked40.912510
17Locked40.39540
18Locked40.38230
19Locked40.98560
20Locked40.311330
21Locked40.313440
22Locked40.98560
23Locked40.98830
24Locked40.37820
3ATDMA0000
4ATDMA0000
wiggydave10
  • 61
Message 6 of 25
13/08/2020 01:19:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 10:19:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 09:09:18ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 02:59:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 12:52:29ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 00:15:18ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/08/2020 13:34:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/08/2020 11:38:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 23:34:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/08/2020 15:06:2ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/08/2020 13:56:32ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/07/2020 16:37:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 17:41:54ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 05:04:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 17:46:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:26:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/07/2020 04:23:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 19:52:19ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 13:35:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/07/2020 12:37:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
John_GS
  • 8.11K
  • 434
  • 707
Message 7 of 25
Hi wiggydave10
Thanks for posting. My apologies for the delayed reply and the lower than expected speeds.
I've ran a check on our system and can see there is a congestion issue in the area. F007940768 is the fault reference. The estimated fix date is the 30th September 2020.
Kind regards,
John_GS
wiggydave10
  • 61
Message 8 of 25
Is there any update on this. The issue still seems to remain and I find that sometimes the connection is a bit iffy.
I notice if I maybe uploading something or streaming something the upload rate drops below the set value, so looks and feels like there is still some issue.
Regards,
wiggydave10
wiggydave10
  • 61
Message 9 of 25
This is todays BQM:
fbccd0543255dabe677c03746b20a919eb8f85d8-16-10-2020
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 10 of 25
Can you post a 'Live Link' to your BQM please.
