fargonone
  • 9
Message 1 of 18
Upload speed consistently 0.08 - slow for weeks
I have been experiencing upload speeds of exactly 0.08mbs about 90% of the time for over a month now. If I reset my router or on a random good day it will be bout 3mbs for a short time (which I think is normal) but the rest of the time it is exactly 0.08mbs.
Download speeds seem to be fine, fluctuating between 40 and 60mbs.
I'm testing on wifi on different devices. This is what has been done so far:
  • Pinhole reset of router (with a tech assistant on chat)
  • In router settings changed wifi settings - channel width for both 2 and 5 bands (with a tech assistant on chat)
  • Pinhole reset with back end changes at Virgin's end (with a tech assistant on chat)
The last one is what fixed it for about a week but it is back to consistent upload speeds of 0.08 now. Every time I try to get through to Virgin chat I am waiting for days on the chat, and then they respond and if you don't get back to them within literally 10 minutes, it starts you at the beginning of the process again which is frustrating to say the least. It took me 10 days in the chat to get through successfully to the tech team last time so I'm giving this forum a go this time to ease the stress levels..! 🙂
Happy to share more information if needed. Thanks in advance.
Tags (4)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 18
Re: Upload speed consistently 0.08 - slow for weeks
How are you connecting your device, Wi-Fi or ethernet cable ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
fargonone
  • 9
Message 3 of 18
My BQM
I have added My BQM link above, but it's only just been set up so might need a few hours to collect data.
I tried to follow the second part of your instructions, I have Hub 3, but when I go to 192.168.0.1 there is no option to "check router status", the only option is to log in.
fargonone
  • 9
Message 4 of 18
I just wondered if anyone has had a chance to look into this?
Anonymous
Not applicable
Message 5 of 18
@fargonone wrote:
We require the stats from your HUB, as requested by Mike, to determine what might be causing your issues.
fargonone
  • 9
Message 6 of 18
Thanks for the reply, as I mentioned above also, I have tried to get that status from the router but I don’t see any option before or on the logon screen, and when I’m logged in I have looked through every menu and can’t see it either. I’m waiting for someone to tell me where to get at the settings as what was said before doesn't get me there.
Anonymous
Not applicable
Message 7 of 18
@fargonone wrote:
Advanced Settings/Tools/Network Status.
fargonone
  • 9
Message 8 of 18
13310000003.738256 qam25
22670000003.538256 qam17
3275000000440256 qam18
42830000003.740256 qam19
52910000004.340256 qam20
6299000000438256 qam21
73070000004.540256 qam22
83150000003.738256 qam23
9323000000440256 qam24
103710000003.238256 qam26
113790000003.738256 qam27
123870000002.538256 qam28
133950000001.938256 qam29
144030000001.438256 qam30
154110000001.538256 qam31
164190000001.538256 qam32
17427000000138256 qam33
184350000001.538256 qam34
19443000000138256 qam35
204510000001.738256 qam36
214590000001.238256 qam37
224670000001.238256 qam38
23475000000138256 qam39
244830000000.738256 qam40
1Locked38.9940
2Locked38.92250
3Locked40.3430
4Locked40.9870
5Locked40.3590
6Locked38.9910
7Locked40.3650
8Locked38.91020
9Locked40.37733
10Locked38.9920
11Locked38.65958
12Locked38.914415
13Locked38.91570
14Locked38.62560
15Locked38.61920
16Locked38.91980
17Locked38.92660
18Locked38.61540
19Locked38.91990
20Locked38.91170
21Locked38.92060
22Locked38.92410
23Locked38.62080
24Locked38.61870
fargonone
  • 9
Message 9 of 18
1394001854512064 qam4
2462001954.025512064 qam3
3537003424.075512064 qam2
4326001303.975512064 qam5
3ATDMA0000
4ATDMA0000
fargonone
  • 9
Message 10 of 18
09/10/2020 06:54:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/10/2020 13:29:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 19:33:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 12:01:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 12:01:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 23:18:19ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 23:18:17ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2020 14:16:8Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 03:48:19ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/09/2020 00:02:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 15:48:19ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 09:52:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/09/2020 07:49:26ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/09/2020 20:25:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/09/2020 10:47:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2020 16:59:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2020 08:52:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2020 15:56:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/09/2020 20:52:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/09/2020 22:53:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
