fulcrumer
  • 27
Message 1 of 13
Upload speed collapsed again!
Usually averages 10mps. Reduced to a crawl over the summer because of two local capacity issues. Fixed after a couple of months.
For the past couple of weeks it has been between 1.7 and 3.5 mps.
Downstream bonded channels Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500001.935256 qam9
22107500001.535256 qam10
32187500001.436256 qam11
4226750000135256 qam12
52347500000.935256 qam13
62427500000.735256 qam14
72507500001.535256 qam15
82587500002.235256 qam16
9266750000235256 qam17
10274750000235256 qam18
11282750000235256 qam19
122907500001.935256 qam20
132987500001.735256 qam21
143067500001.536256 qam22
153147500001.536256 qam23
163227500001.735256 qam24
173307500001.936256 qam25
183707500000.736256 qam26
193787500000.936256 qam27
20386750000136256 qam28
21394750000136256 qam29
224027500001.236256 qam30
234107500001.236256 qam31
244187500001.536256 qam32
1Locked35.7110632
2Locked35.798751
3Locked36.37470
4Locked35.715850
5Locked35.7213216
6Locked35.5247711
7Locked35.533631
8Locked35.5271812
9Locked35.7139455
10Locked35.78340
11Locked35.74870
12Locked35.76488
13Locked35.710724
14Locked36.34730
15Locked36.36310
16Locked35.76320
17Locked36.35820
18Locked36.37422
19Locked36.38260
20Locked36.38870
21Locked36.37270
22Locked36.36140
23Locked36.67590
24Locked36.36640
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1257996774.746512016 qam4
2325999904.725512032 qam3
3393999754.725512032 qam2
4462000004.75512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
https://www.thinkbroadband.com/broadband/monitoring/quality/share/602a55a88d4d5c7005912e1d84a51afa527cf931-08-11-2020
fulcrumer
  • 27
Message 2 of 13
Re: Upload speed collapsed again!
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057+voc-b.cm
SFID469552
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID469551
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
.1;CM-VER=3.0;
05/11/2020 01:19:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:18:19criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:13:17Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:13:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2020 01:13:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 13:31:46ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 13:13:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 12:06:28ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 11:55:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 11:13:57ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 07:17:39ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 04:06:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 19:28:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 05:50:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 03:43:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 00:12:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
fulcrumer
  • 27
Message 3 of 13
Andrew-G
  • 6.98K
  • 1.22K
  • 3.05K
Message 4 of 13
Looks like an upstream noise issue, because the upstream modulation is all over the place.  I've flagged this for the forum staff to advise.
Emma_C
  • 8.28K
  • 512
  • 559
Message 5 of 13
Hi Fulcrumer,
Really sorry you're having these issues, it's certainly not the level of service we aim to provide.
I've had a look at the back end of things and can see we're aware of an issue under the reference F008060159. This is due to be fixed by the 30th November at 09:00AM.
During this time you might find that the services are intermittent but the team will have sorted as soon as possible.
Let us know how you get on after this time.
Emma_C - Forum Team
fulcrumer
  • 27
Message 6 of 13
Thanks for letting me know.
But this is the third fault in 6 months - each with a long lead in time to be fixed. it would be helpful if we were told about the issues when they arise rather than having to post on forums about it. i would expect at least some reference when when checking service status.
Emma_C
  • 8.28K
  • 512
  • 559
Message 7 of 13
I can fully appreciate that but I'm afraid these issues aren't put onto the service page. If the issue isn't fixed by the time we've given then message me directly and I can give you an update, or post on here and we can continue to update you as well.
Emma_C - Forum Team
fulcrumer
  • 27
Message 8 of 13
Any news/progress?
My upload speed is currently 0.88 mbs - which is intollerable.
Emma_C
  • 8.28K
  • 512
  • 559
Message 9 of 13
Really sorry this is still on going.
Another ticket has been raised in the area due to low SNR issues, this has the reference F008628805.
This is due to be fixed by the 8th December by 09:30AM.
Again any issues after this date please let us know and we can keep you updated.
Emma_C - Forum Team
fulcrumer
  • 27
Message 10 of 13
Has this been fixed now? I doubt it as my internet connection, for the past two days, keeps dropping. Current upload speed is  3.2mbs (Max).Yesterday I thought - good - must be fixing it. But now not so sure.
I am afraid my patience is now very stretched. Could I have an update on the current situation?
Thank you
