charlottexoxoxo
Just joined
Upload speed below 0.5
Hello, recently I've noticed that our upload speed has been really really slow. It is meant to be 15 in the package we have but I am lucky to get over 0.5. It is making it impossible to do anything what do I do in this situation and is there any fix?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Upload speed below 0.5
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
The sooner the better …
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
