GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 1 of 20
Upload speed and gaming issues and packet loss in the evening
My connection has not been running great the past week in the evenings, when gaming or trying to upload any files regardless of location (maybe a connection between the 2 at a guess)
At first I thought it was just gaming for the first few days, but when trying to upload anything in the evening my upload speed drops to 1.5MB, during the day it is 4.5MB
My voice chat is also lagging on Xbox and Discord.
I have also noticed bits of packet loss during this time, if you look at the graph at the bottom it started just after 8pm till 10pm, during this time I was gaming. The hump after 5pm was me uploading which started at 4.5MB then started to slow at around 6pm.
Downstream
12990000003.438256 qam21
21390000004.638256 qam1
31470000004.338256 qam2
4155000000438256 qam3
51630000003.738256 qam4
61710000003.938256 qam5
71790000003.738256 qam6
81870000003.738256 qam7
91950000003.738256 qam8
10203000000338256 qam9
11211000000338256 qam10
122190000002.738256 qam11
132270000002.538256 qam12
14235000000238256 qam13
152430000001.738256 qam14
162510000001.238256 qam15
172590000000.738256 qam16
18267000000138256 qam17
192750000001.438256 qam18
202830000002.538256 qam19
21291000000338256 qam20
223070000003.538256 qam22
233150000003.538256 qam23
243230000003.238256 qam24
Upsteam
13260000037.3512064 qam7
22580000037.3512064 qam8
33939996638.8512064 qam6
44620000038.8512064 qam5
Packet loss
_____________________
My Broadband Ping - VM - TP Link 13/04/2021
conman33158
  • 1.42K
  • 121
  • 260
Knows their stuff
Message 2 of 20
Re: Upload speed and gaming issues and packet loss in the evening
To make any informed decision you would need to copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 3 of 20
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1299000000338256 qam21
21390000004.538256 qam1
31470000004.138256 qam2
61710000003.738256 qam5
71790000003.538256 qam6
81870000003.538256 qam7
91950000003.538256 qam8
102030000002.938256 qam9
112110000002.938256 qam10
122190000002.538256 qam11
132270000002.238256 qam12
142350000001.738256 qam13
152430000001.438256 qam14
16251000000138256 qam15
172590000000.538256 qam16
182670000001.238256 qam17
192750000002.238256 qam18
212910000002.738256 qam20
223070000003.238256 qam22
233150000003.238256 qam23
24323000000338256 qam24
1Locked38.9350
2Locked38.6240
3Locked38.9280
4Locked38.6360
5Locked38.6290
6Locked38.6200
7Locked38.9140
8Locked38.9140
9Locked38.970
10Locked38.6160
11Locked38.980
12Locked38.9180
13Locked38.6300
14Locked38.6220
15Locked38.9160
16Locked38.6440
17Locked38.9390
18Locked38.9370
19Locked38.9140
20Locked38.9330
21Locked38.9140
22Locked38.9100
23Locked38.9220
24Locked38.9320
3ATDMA0000
4ATDMA0000
GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 4 of 20
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Removed by Me
SFID10646
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID10645
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Network LogTime Priority Description
10/04/2021 09:09:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:cc;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 02:51:8noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 02:51:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/04/2021 08:09:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 22:02:59noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt0**-b.cm modified;CM-MAC=**:**:**:**:***:**;CMTS-MAC=**:**:**:**:**:cc;CM-QOS=1.1;CM-VER=3.0;
04/04/2021 22:02:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2021 11:10:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2021 10:02:59noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt0**-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2021 10:02:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2021 19:44:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2021 13:45:40noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt0**-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2021 13:45:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/03/2021 06:34:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2021 17:20:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt0**-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/03/2021 17:20:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/03/2021 15:08:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**:40:53;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/03/2021 05:20:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt0**-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/03/2021 05:20:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2021 23:46:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2021 05:31:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt0**-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a1a0460acac85e2ea6f1b7baf1c9053b
GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 5 of 20
I do have to ask why ThinkBroadband and not f8lure mouselike or both?
I know a BQM is more know etc.., maybe that why.
The more graphs the better, I think, as they may take different routes over the internet.
conman33158
  • 1.42K
  • 121
  • 260
Knows their stuff
Message 6 of 20
Your router stats look fine mate but you have a recurring theme with "DHCP RENEW WARNING" in your network log. Are you using a third party router as this is usually an indication that the router cannot handle DHCP very well?
Also your BQM doesn't look great, have you Checked service status and also called 0800 561 0061 for the most up to date faults information in your area?
GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 7 of 20
Yes I am using an Asus RT-AC86U but have a new router coming a TP Link AX6000 in the next few days I believe.
My issues started about 1 week ago, was running fine till then.
Could the DHPC error be due to turn off and on the router and or hub to reboot it?
My router get bogged down sometimes and affect both local and internet speed.
I check local stats and called the 0800 and no issues
conman33158
  • 1.42K
  • 121
  • 260
Knows their stuff
Message 8 of 20
Maybe best to wait on the new router and see how that goes, or in the meantime you could try running the Hub in router mode and see if you're getting the same issues, that way you will know for sure if the router is the problem. Asus is normally pretty good as I use their gear myself, maybe it's just developed a fault of some sort, maybe it needs a re-flash and probably wouldn't be a bad idea to do a pinhole reset on the Hub as well. Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection then you can fire it back into modem mode 🙂
Yeah turning it off and on will force it to renew DHCP each time.
GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 9 of 20
I give that a try later and will also reset hub when I get my new router
GazCBG
  • 337
  • 5
  • 28
Fibre optic
Message 10 of 20
I have just reset the hub and am now using the hub in router mode till my new router get here.
I have also updated my IP on my BQM, so the same link above will work.
BQM link just in case: https://www.thinkbroadband.com/broadband/monitoring/quality/share/a1a0460acac85e2ea6f1b7baf1c9053b
I post back in the morning with an update
