96fauj
  • 92
Dialled in
Message 1 of 12
Upload speed a third of what I should expect to get.
I've just been changed to a M350 package. My upload speed is coming in around 10mbp/s on Speed test. I should expect between 34-36.
(I have also set up a BQM but that will take 24 hours to show anything useful).
139000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
11390000002.238256 qam1
21470000002.238256 qam2
3155000000238256 qam3
41630000002.238256 qam4
51710000002.538256 qam5
61790000002.738256 qam6
71870000002.938256 qam7
8195000000338256 qam8
9203000000338256 qam9
102110000002.938256 qam10
11219000000338256 qam11
12227000000338256 qam12
132350000003.238256 qam13
142430000003.238256 qam14
152510000003.538256 qam15
162590000003.238256 qam16
172670000003.538256 qam17
182750000003.538256 qam18
192830000003.738256 qam19
202910000003.938256 qam20
21299000000438256 qam21
223070000003.538256 qam22
233150000002.738256 qam23
243230000002.538256 qam24
1Locked38.6130
2Locked38.680
3Locked38.680
4Locked38.960
5Locked38.690
6Locked38.6220
7Locked38.960
8Locked38.670
9Locked38.9200
10Locked38.980
11Locked38.960
12Locked38.970
13Locked38.650
14Locked38.940
15Locked38.960
16Locked38.960
17Locked38.970
18Locked38.970
19Locked38.970
20Locked38.960
21Locked38.9190
22Locked38.6190
23Locked38.980
24Locked38.910
13940000041.5512064 qam6
24620000041.5512064 qam5
33260000041.5512064 qam7
42579995141512064 qam8
3ATDMA0000
4ATDMA000
0
Downstream Service Flow
SFID666086
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Upstream Service Flow
SFID666085
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
My Broadband Ping - Hub 4 - November - New IP BQM
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 12
Re: Upload speed a third of what I should expect to get.
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
96fauj
  • 92
Dialled in
Message 3 of 12
Hi, so I'm using a CAT6 cable. Initially I was connecting through the Computer - Linksys router - Hub.
The reported speed is 1000 (Mbps).
I spoke to the most frustrating customer services member who tried to take me through diagnostics. Had me take the Hub out of modem mode. Connect directly (I used the cat6 cable again) and run the same speed tests. Then in safe mode.
Each time I ran the test, the upload speed dropped by about 1mb.. so initially it was around 10mb and this time round it was on 6mb. On SamKnows it was 7pm.
So the account is under my dads name and when I had changed my packaged to this m350 I had actually set setup a password with the agent so that I can access my account but this doesn't seem to have gone through. In order for me to get an engineer visit, I'm probably going to have to call again.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 12
VM will not accept speed tests through third party equipment which is understandable.
The sooner the better …
96fauj
  • 92
Dialled in
Message 5 of 12
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 12
Can you log into the Hub settings and set your Hub Firewall up as shown below.
Hub-3-Firewall
96fauj
  • 92
Dialled in
Message 7 of 12
It was already setup like this. I've just hit Apply Changes in case.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 12
Try setting up a new BQM.
96fauj
  • 92
Dialled in
Message 9 of 12
96fauj
  • 92
Dialled in
Message 10 of 12
https://www.thinkbroadband.com/broadband/monitoring/quality/share/c639e30dbf7c8cd2e3239d20e6ddd45106...
Had to create yet another one as this previous one also stopped working.
