Would need to check the signal levels if could go to
http://192.168.0.1 or if using modem mode
http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots, are you talking about the upload speed or download, since upload is around 20mbps, or 2Mbps.
