nennolello
  • 20
Message 1 of 35
Upload less than 1mb and Download cut in half
Hi All,
I am kind of desperate because no matter how many time I call VM and no matter what I do I cannot resolve this issue. Until last year my M100 was perfect with speed test reporting 114Mb download and +/-9Mb upload.
Due to Cancer treatments I was forced to stay abroad and since I am back I found my connection is awful ( Broadband and Computer were always on while I was away ).
I am now getting 40/45Mb download on average and between 0.5 to 3Mb in upload. It gets worst during working hours and the upload speed rarely recover significantly. I called the customer service and so far this is what I have been told ( and didn't solve my issue 😞
- They sent the signal to the router -> didn't do anything other than noticing that downstream is better when the hub is in router mode but it seems to be a common problem recently to many other users
- Better to keep the Hub in Router mode -> I always had my hub in modem mode since I know what I am doing and I prefer to have my business grade equipment to handle my home network and my wifi.
- They cannot get the statistics of your line -> Surely this means something is not right ?
 They seems to do not find anything wrong with my router ( at least this is what customer service keep telling me ) and the only thing they have done is to put me under monitoring for 30days.
The only problem with the above is that by reading the email I received if they don't find anything ( remotely ) this is the only OFFER I get: "If we can’t fix it within 30 days, we’ll let you know by email and you’ll be eligible to end your agreement immediately with no early disconnection fees to pay."
I just want to have a decent connection and I am happy to provide any further details to whoever can help me out.
Thank you so much guys
nennolello
  • 20
Message 2 of 35
Re: Upload less than 1mb and Download cut in half
Just to provide a bit more info:
DOWNSTREAM
1138750000-1.238256 qam1
2146750000-1.538256 qam2
3154750000-1.438256 qam3
4162750000-138256 qam4
5170750000-1.238256 qam5
6178750000-138256 qam6
7186750000-0.738256 qam7
8194750000-140256 qam8
9202750000-1.438256 qam9
10210750000-1.438256 qam10
11218750000-1.738256 qam11
12226750000-238256 qam12
13234750000-2.438256 qam13
14242750000-3.438256 qam14
15250750000-2.938256 qam15
16258750000-3.438256 qam16
17266750000-338256 qam17
18274750000-3.238256 qam18
19282750000-2.738256 qam19
20290750000-2.438256 qam20
21298750000-2.438256 qam21
22306750000-2.438256 qam22
23314750000-2.738256 qam23
24322750000-238256 qam24
1Locked38.949646916
2Locked38.915020
3Locked38.900
4Locked38.960
5Locked38.600
6Locked38.900
7Locked38.9180
8Locked40.350
9Locked38.960
10Locked38.940
11Locked38.930
12Locked38.950
13Locked38.630
14Locked38.600
15Locked38.9110
16Locked38.970
17Locked38.9130
18Locked38.600
19Locked38.970
20Locked38.950
21Locked38.960
22Locked38.660
23Locked38.900
24Locked38.600
UPSTREAM
13940000047512064 qam2
24620000047.5512064 qam1
33260000046.8512064 qam3
42580000046512064 qam4
1ATDMA0010
3ATDMA0000
4ATDMA0000
Thank you so much all
Kath_F
  • 34.76K
  • 1.34K
  • 2.82K
Message 3 of 35
Hi nennolello,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear you've been having an issue with the speed of your broadband connection.
When it comes to speeds, the checks we run need to be with the Hub and any third party equipment disconnected from it. I'm happy to take a look in to things further for you but I've been unable to locate your account via your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
Kath_F
Kath_F
  • 34.76K
  • 1.34K
  • 2.82K
Message 4 of 35
Hi nennolello,
Thanks for coming back to me via private message with your information.
I have taken a look at the account and checked the Hub over. All stats are looking good and there are no issues showing in the area either.
As you've mentioned things are usually fine when the hub is in normal mode, can you try testing the connection when in Modem mode and connected directly to a PC/Laptop?
Make sure the ethernet cable to are using a a cat 6 and also ensure your network card is not set to 100mb.
Pop back and let us know how things go.
Kath_F
  • 6.82K
  • 593
  • 1.79K
Message 5 of 35
To monitor your circuit you will need to setup a BQM here  www.thinkbroadband.com/ping
This will monitor and record your circuit so you will have a picture of how it is performing.   If you are swapping between Router and Modem modes, you will need to update the monitor with the correct WAN IP addresses to keep it working.
nennolello
  • 20
Message 6 of 35
Hi Kath,
Values are not fine even in normal router mode since during “working” hours (8-18) upload start to decrease down to 0.8/0.4 mbit.
I got an internet monitoring set up on my raspberry pi, I’ll take a screenshot and upload the graph to show you.
thanks
nennolello
  • 20
Message 7 of 35
These are the values for speedtest in the last 24h ( with the hub in normal/router mode ). All test are than via wired cable so there's no WIFI speed involved here.
As you can see Upload started to decrease again to levels ( upload ) that are just not right.
Carley_S
  • 3.16K
  • 165
  • 267
Message 8 of 35
Hi @nennolello,
Thank you for providing this information. I have taken another look at our systems and there are no power level issues and everything looks in spec at our end within the area. Is this issue just on your upload speeds or you see any issues on download as well?
Carley - Forum Team
nennolello
  • 20
Message 9 of 35
Hi @Carley_S,
As you can see from my attachment in the last two days things are started to look better ... aside from the fact that the connection is still not stable, I'll explain:
Now that upload and download are good I am still experiencing random latency in loading sites, video and audio calls sometime dropping etc. The reason seems to be internal to VM in the sense that it takes a lot of time for a request to exit VM and only once it's out the request lands normally and fast.
Ping is good but if you do a traceroute you can see that it takes a lot of time in the first few hops ( Ex. Hub to VM Server, VM Server to another VM Server ). DNS is not the culprit as it happens regardless of the DNS you are going to use ( VM ones, GoogleDNS, Cloudfire, etc. ) so my two cents are on to the fact that there must be somewhere some kind of misconfiguration along the line within VM.
PS: Wifi has nothing to do with it because all my tests are conducted via ethernet cable.
I understand it might be too technical and/or hard to narrow down but this is now want is preventing me from having a decent experience.
traceroute to google.com (142.250.178.14), 30 hops max, 60 byte packets
 1  192.168.0.1 (192.168.0.1)  2.387 ms  3.256 ms  3.736 ms
 2  * * *
 3  popl-core-2b-ae27-0.network.virginmedia.net (62.255.161.125)  20.505 ms  20.690 ms  23.600 ms
 4  * * *
 5  eislou2-ic-4-ae0-0.network.virginmedia.net (62.254.59.130)  30.224 ms  29.091 ms  29.660 ms
 6  m422-mp2.cvx3-a.ltn.dial.ntli.net (213.104.85.166)  44.633 ms  18.540 ms  24.069 ms
 7  * * *
 8  108.170.246.161 (108.170.246.161)  29.765 ms 108.170.234.230 (108.170.234.230)  30.538 ms  30.032 ms
 9  108.170.246.176 (108.170.246.176)  24.124 ms 142.250.215.125 (142.250.215.125)  19.746 ms 108.170.246.144 (108.170.246.144)  22.944 ms
10  209.85.143.67 (209.85.143.67)  22.826 ms lhr48s27-in-f14.1e100.net (142.250.178.14)  13.868 ms 216.239.58.179 (216.239.58.179)  19.594 ms
nennolello
  • 20
Message 10 of 35
Hi All,
Connection keep freezing for few seconds so that any kind of call/videocall drop, sometime I need to wait 5/10 sec to load a web page etc.
As suggested from @Adduxi I tried to setup a broadband monitor, hope it will help.
Thanks all
My Broadband Ping - NennoLello
