tortle
  • 12
Message 1 of 19
Upload Speeds regularly unstable and less than 10% of normal since January
Posting here because at this stage we don't know what else to do 😞
We've been with Virgin for about 12 years now and have never had any issues until the start of this year. We're on the M350 package and every day or two (usually in the evenings but not always) our upload speed goes from about 36Mbps up to an unstable 0-3. When this happens it can be like this for hours at a time. I stream to Twitch and this has taken down 15 streams of mine this year, not great.
It effects every device, over wired or wireless at the same time, whether all the PCs are on, or just one. So it doesn't seem to be an issue with our computers (which have been the same for a few years now anyway).
We've run countless samknows speed tests and the upload stream on the router side is also effected, which seems to indicate the issue is on the street maybe? We've followed support advice to do things like pin reset the router, etc. but none of that has helped.
We've had technicians out twice. The first time they fitted and attenuator and said someone would look at the outside cables the next day. They did that, but sadly the issues continued.
Then yesterday they replaced our router to see if that would help. Sadly, the problem happened again last night with the new router, only a few hours after it had been installed!
This has been going on for 6 weeks now and we really don't know what else to do. From looking at these forums and twitter it seems there are a lot of folks having the same upload issue.
With the new router I'll need to wait for it to happen again to check the logs and data pages to see if the upstream channels have an issue (they look fine now, all showing as 64). Sadly I don't have the logs from the old router and they've taken it away.
Any advice would be appreciated. Thanks.
  • 1.87K
  • 116
  • 430
Super solver
Message 2 of 19
Re: Upload Speeds regularly unstable and less than 10% of normal since January
Share the results of the Samknows Realspeed tests that show there is a problem with the performance at the Hub.
tortle
  • 12
Message 3 of 19
Sure. Here are a few from over the last couple of weeks. Hope they are sufficient:
I didn't know about SamKnows initially so hadn't been using that since the beginning.
The Ookla speed tests on Virgins page did at least partially demonstrate the same issue, we didn't know at that point if it was device or router side.
  • 1.87K
  • 116
  • 430
Super solver
Message 4 of 19
Good for the VM Team to be able to see the range of speed test with serious Upstream issues.
Are there known local faults if you call 0800 561 0061   ( automated service )
From Check router status >>> Upstream
What do the Upstream Bonded Channels show ?
Copy & Paste the text to show the information.
tortle
  • 12
Message 5 of 19
Ah. We've never called the number but we did visit the check services page:
https://www.virginmedia.com/support/help/check-services/address-identification/identify
Which either didn't see a fault or failed to load entirely.
We did talk to a customer service agent via the chat interface on mobile during one of the incidents and she couldn't see an issue.
She asked us to take a photo of SamKnows and this is what it showed:
Next time we'll call the number.
We didn't know about the Upstream Bonded Channels pages until reading the forums here today so next time the issue happens I will grab a screenshot.
At the moment, upload and download speeds are fine. All the upstream channels show 64 qam, no timeouts, etc.
Wish I'd known to check this last night when it fell over...
13659997945.8512064 qam11
22359998644.3512064 qam13
33009999645.8512064 qam12
44309998145.8512064 qam10
54959999845.8512064 qam9
3ATDMA0000
4ATDMA0000
5ATDMA0000
Thanks for the help so far!
  • 1.87K
  • 116
  • 430
Super solver
Message 6 of 19
Call 0800 561 0061 - local fault are just what you need to hear about.
The Post Code checker frequently shows no issue.
tortle
  • 12
Message 7 of 19
Ah ok, cheers. Number says no local issues currently but we'll call that next time it happens.
tortle
  • 12
Message 8 of 19
Ok, so it's happening again as I type this. Upload bouncing about erratically between 0 and about 4mbps.
Called the number, no local faults in our area.
Checked the Upstream Bonded Channels, a couple of them are down to 32 qam and 1 seems to drop to 16 qam every so often:
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
22360000045.5512016 qam13
33010000045.8512064 qam12
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0010
5ATDMA0000
22360000044.3512032 qam13
33010000045.8512032 qam12
3ATDMA0000
4ATDMA0010
5ATDMA0000
3ATDMA0000
4ATDMA0010
5ATDMA0000
Took some screenshots of SamKnows as well as the Upload Bonded Channels.
There certainly seems to be a correlation between channels dropping to 16 and 32 qam and the upload on the router side falling away:
2023-02-14 22_48_36-.png2023-02-14 22_48_18-.png2023-02-14 22_46_11-.png2023-02-14 22_38_05-.png2023-02-14 22_42_31-.png
Hope these help demonstrate the problem!
tortle
  • 12
Message 9 of 19
Sadly it's happening again tonight. That's 3 nights in a row. Another stream ruined. Totally unusable 😞
Same problem again it seems, QAM drops on the upstream channels due to noise ingress.
We were on to the network faults team earlier today, who were able to see the issue from last night and assured us it would be fixed by tomorrow so who knows....
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
36599979
45.8
5120
64 qam
11
2
23600000
45.5
5120
16 qam
13
3
30100000
45.8
5120
32 qam
12
4
43099981
45.8
5120
64 qam
10
5
49599998
45.8
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
1
0
5
ATDMA
0
0
0
0
tortle
  • 12
Message 10 of 19
Same problem again tonight. 4 nights in a row now. Looks like it's gonna be 4 hours or so of this every night 😞
Same channels dropping down as usual, with same the effect on upload speeds:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
36599979
45.8
5120
64 qam
11
2
23600000
45.5
5120
16 qam
13
3
30100000
45.8
5120
64 qam
12
4
43099981
45.8
5120
64 qam
10
5
49599998
45.8
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
1
0
5
ATDMA
0
0
0
0
