Upload Speed
prscampbell
Hi, I'm experiencing (and have been for a week) upload speed issues. I usually get around 38Mbps but I can't seem to get anywhere above 8Mbps on speed test websites, and worse connections via other services.
Wanted to see if there's anything I could do to improve it, or if I just have to wait...
14990000007.437256 qam36
22350000007.538256 qam13
32430000008.438256 qam14
42510000008.638256 qam15
52590000007.537256 qam16
62670000006.437256 qam17
72750000006.137256 qam18
8283000000737256 qam19
9291000000838256 qam20
102990000007.537256 qam21
113070000005.937256 qam22
123150000005.337256 qam23
13323000000637256 qam24
144110000006.938256 qam25
154190000007.538256 qam26
164270000008.538256 qam27
174350000008.638256 qam28
18443000000838256 qam29
194510000007.638256 qam30
204590000007.938256 qam31
214670000008.538256 qam32
22475000000938256 qam33
23483000000938256 qam34
244910000008.438256 qam35
1Locked37.61780
2Locked38.613427
3Locked38.611239
4Locked38.6840
5Locked37.61550
6Locked37.32540
7Locked37.32690
8Locked37.61600
9Locked38.6780
10Locked37.61150
11Locked37.64260
12Locked37.68330
13Locked37.64020
14Locked38.61170
15Locked38.6520
16Locked38.6490
17Locked38.9500
18Locked38.9580
19Locked38.9340
20Locked38.9370
21Locked38.9390
22Locked38.9590
23Locked38.9640
24Locked38.6550
13940001430.8512016 qam2
23259995830512016 qam3
32579992729.3512016 qam4
44620001530.3512016 qam1
1ATDMA009230
2ATDMA00620
3ATDMA0010290
4ATDMA007590
28/12/2022 10:29:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2022 10:24:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2022 07:52:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2022 07:46:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2022 00:38:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2022 00:37:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2022 07:20:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2022 01:56:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10 REPLIES 10
Superstar
All the Upstream bonded channels have downgraded from 64 qam ( normal rate ) to 16 qam ( lowest rate ) - hence the slower uploads.
The use of 16 qam is not customer fixable, perhaps there is a known fault or a new fault in the locality.
As above, but you can try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
A 60 second factory pinhole reset may put the US back to 64QAM for a short while ?
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Note if there is an area fault, VM will not send a technician until the fault is cleared.
Wait here a day or two and a VM Mod will pick this up
Yeah, the website and the phone number both say there's a local fault in my area but that's been the case for a week. Was just hoping there might be something I could do to fix it without having to wait.
Had this exact same issue a month ago. I'll give the reset a go, but I suspect I'll just have to wait for it to be fixed again.
EDIT: No improvement after resetting. Will just have to wait until they fix the issue locally.
Hello prscampbell.
Thank you very much for joining our Community.
Can I just apologise for the intermittent service.
We can run a few tests from here and check on your equipment.
Sadly its not showing anything wrong, So I will need to send you a private message to gain account access and run further tests.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
Hello prscampbell,
Thanks for those details.
I have had a look at the area and we have an SNR issue right now.
This is due to be fixed on the 03/01/2023.
If it is still an issue after the above date, pop back on here and quote this reference number
F010357857.
That way we can update you.
Sorry for any inconvenience this may be causing you.
Gareth_L
It is still not working.
Reference number: F010357857
Hi @prscampbell
Thanks for your post
I am going to drop you a private message now to collect some more information and investigate further, please keep an eye on your inbox for a message from myself.
Travis_M
Hi @prscampbell
Thanks for your response
The issue is still ongoing unfortunately ongoing and the team are looking to have this resolved as soon as possible, the estimated fix date is currently 11 JAN 2023 09:00
Travis_M
I've had this week that my issue will be fixed on:
03/01/23
04/01/23 @ 2pm
06/01/23 @ 9am
11/01/23 @ 9am
You no longer need to update me as to when you think this issue will be fixed because the estimates are a waste of time.
